Falcon Player (FPP) => Falcon PiCap => Topic started by: robj2022 on August 13, 2022, 11:42:27 AM
Title: PiCap Slow DMX output?
Post by: robj2022 on August 13, 2022, 11:42:27 AM
Falcon PiCap to DMX is very slow output.
Testing with a Falcon V4 works great. PiCap doesn't.  I'm using the same cables in both setups, no wifi involved.
xlights on PC, Output to Lights -> Falcon V4->DMX pixel changes instantly
xlights on PC, Output to Lights -> Falcon PiCap->DMX pixel changes after about 2-3 seconds.
PiCap running on a Raspberry Pi3, FPP version 6.0.2-8-g8bc1f372FPP in Player mode
Channel input enabled, 1 input active, E131, unicast, FPP Channel start 1, end 510, universe 1, universe count 1, universe size 510
Channel outputs: other, active DMX-Open, start channel 1, Chanel count 16, Desc blank, Port ttyAMA0
PiCap works, sending the right pixel color, it just is tremendously slow to update, and rapid changes are lost in the time lag.Am I in a wrong mode or missing an important step?
Title: Re: PiCap Slow DMX output?
Post by: CaptainMurdoch on August 14, 2022, 09:46:28 PM
Do the DMX pixels change properly when you run a sequence?  I believe that xLights changes some settings in FPP when you turn on (or off) Output to Lights, so that could be what is causing the delay.
Are you saying pixels are always delayed when xLights is sending through FPP out the DMX port?  There should not be any delay.  I would also use the Channel Tester page in FPP to see how quickly the DMX pixels respond when you change the settings on the test page.  There will be a slight lag as the new test data is setup, but it isn't anywhere near 2-3 seconds.
Post by: JerryPlak on August 15, 2022, 06:49:50 AM
something to try..
on the FPP setting add the check mark to the "Always transmit channel data"
to see if helps
Post by: bloojoop on August 15, 2022, 10:34:16 PM
If it is just when you start the test, make sure "Auto upload configuration" is NOT checked.  That is the setting that Chris was referring to just above.  It is generally recommended not to have that setting checked.
