Total Members: 15301
Latest: magicx
New This Month: 4
Total Topics: 15248
Most Online Today: 53
Guests: 26
Total: 28
FPP 6.0 Released!
Started by dkulp, July 26, 2022, 05:53:40 PM
virgil1
Quote from: virgil1 on August 16, 2022, 04:17:44 PM
Quote from: virgil1 on August 16, 2022, 03:41:15 PMI am having the same problem. Tried 6.  Tried 6.02.  Tried with my backup config, tried without it.  It doesn't see the USB Soundblaster.  Went back to my old SD card with v4.6.1, works fine.  Raspberry Pi 3B+.
Paul
Trying 5.5 now.  Will post updates.  Forgot to mention I have a piCap, and a Soundblaster 3 USB.
5.5 worked great!  I think I'll stick with that(better than v4.6.1), but please let me know if I can help with any additional info to debug.  I tried 5.5 with 'vanilla' (not putting my backup config on it) and with my config.  Both worked fine.
#31
Quote from: virgil1 on August 16, 2022, 03:41:15 PMIt doesn't see the USB Soundblaster.  Went back to my old SD card with v4.6.1, works fine.  Raspberry Pi 3B+.
I doubt it is the software. Have you updated to the most recent version of FPP? Do you have the UI Password enabled (this is usually not recommended and known to cause issues)
Here is one on a Pi 3B
You cannot see attachments on this board.
And on a 3B+
virgil1
Yes, UI Password enabled.  How would that stop the USB Sound Card from working?  I can try installing and disabling all passwords.  I did update to the latest FPP and OS.
Quote from: virgil1 on August 16, 2022, 11:35:19 PMYes, UI Password enabled
Is there a reason for that?
Quote from: virgil1 on August 16, 2022, 11:35:19 PMHow would that stop the USB Sound Card from working?
There was a bug that would not allow a few settings options to be displayed because of the UI password.
Quote from: virgil1 on August 16, 2022, 11:35:19 PMI can try installing and disabling all passwords.
That should fix your problem.
Quote from: virgil1 on August 16, 2022, 11:35:19 PMI did update to the latest FPP and OS.
You probably didn't have the latest update, because it was fixed in one of the more recent versions.
virgil1
Reinstalled, didn't enforce UI password(set as disabled), works fine now.  Back on 6.  Thanks for the help!
Dgrimard
For anyone else struggling with the Soundblaster not showing up - or really anything showing up in the sound settings:
Symptoms: I was running version 6.0 adn added a SB Play 3 USB.  I rebooted and nothing showed up in the audio section, and even the previous default options were gone.  Upgraded to 6.02 (cant rember what version of 6 I was on before) but it didnt help any.  In the troubleshooter it showed I had a soundblaster Play 3 connected, but the Audio section showed nothing - not even the derfault Pi4 autio options that is upposed to be default.  I had this problem before when I had the GUI password option enabled (after upgrade to version 6) and once I disabled it then i saw the Pi4 Audio device there.
To get it to work I:
Re-enabled the GUI password option, and then reboot, then disable it again, reboot, and then it showed in the FPP GUI properly.
So it is something with the GUI password breaking the detection of the audio device.
Quote from: Dgrimard on September 05, 2022, 10:13:30 PMSo it is something with the GUI password breaking the detection of the audio device.
Can you try with the latest version of 6.0?  These was a bunch of problems related to UI password breaking things fixed about a month ago.
#38
Quote from: Dgrimard on September 05, 2022, 10:13:30 PMFor anyone else struggling with the Soundblaster not showing up
I have two Pi4s and one Pi3b+ and no issues at all with the Sound Blaster showing up.  I have had the FPP keep rebooting if I do not select the sound blaster as the default device, but once the sound blaster has been selected every thing seems to work fine, other than I get constant errors in the "/var/log/syslog" file.
Sep  6 04:09:35 XMas-FPP fppd[1742]: ALSA lib pcm.c:8545:(snd_pcm_recover) underrun occurred
Sep  6 04:09:37 XMas-FPP fppd[1742]: ALSA lib pcm.c:8545:(snd_pcm_recover) underrun occurred
Sep  6 04:09:38 XMas-FPP fppd[1742]: ALSA lib pcm.c:8545:(snd_pcm_recover) underrun occurred
Sep  6 04:09:39 XMas-FPP fppd[1742]: ALSA lib pcm.c:8545:(snd_pcm_recover) underrun occurred
#39
Quote from: Dgrimard on September 05, 2022, 10:13:30 PMTo get it to work I:
The GUI password issue has been fixed. Typically using a GUI password does not provide any security and can cause other issues. It is not typically used for normal functionality.
deanathpc
I just did some backups after I finally got everything talking to each other correctly finally.  I am currently running FPP v6.0.2-8 and noticed the backup file has a v to it.  v5_todaysdate_time.json
Assuming nothing to worry about?
Dean
Stafford, NY
FPP, F16v2R's, SanDevice, LE's, xLights
Is it possible to restore via /boot partition? by EricD
October 02, 2022, 11:17:17 PM
new piCaps in the works? by Bwinter
October 02, 2022, 11:07:24 PM
Projector video for just one video source by Poporacer
October 02, 2022, 09:21:09 PM
PiCap w/Controller? by james-s
October 02, 2022, 05:06:52 PM
F16V4 port 5 Lights flicker by rudybuddy
October 02, 2022, 04:18:23 PM
Smartthings Integrations by james-s
October 02, 2022, 01:26:22 PM
Advatek Vortex 48 channel DC controller by CeP
October 02, 2022, 05:34:34 AM
Upgraded to FPP V6.1.1 - Network Settings do not have "Interface Routing" option by Poporacer
October 01, 2022, 10:24:15 PM
FS Kulp K-8B Controller, Complete by poolprousa
October 01, 2022, 08:31:43 PM
60+ Ray Wu Cables, Pigtails, misc by jnealand
October 01, 2022, 08:57:49 AM
