Total Members: 16480
Latest: tcooper
New This Month: 12
Total Topics: 16479
Most Online Today: 109
Guests: 74
Total: 74
Set Time/Date
Started by Rick, May 12, 2022, 10:42:52 PM
Rick
On the "Settings" tab on the Falcon Controllers page I am trying to set the "Date/Time".  I can get the correct date/time from the "Get Date/Time" button.  I have saved the settings. I have installed the correct button battery on the controller.  However, every time I power down the controller I lose the date/time.  If I "Ping" the "Set Date/Time" I get an response error "Error in response: 503 Ping Failed".  I have "Internet Access" checked.  Any help on this?  I am going to be running this in "Player" mode from an SD card and need the time to be correct without the internet.You cannot view this attachment.
I can not find a place on the controller that shows you what time it thinks it is? Any help here?
What controller are you using and what is its firmware version?
Quote from: Rick on May 12, 2022, 10:42:52 PMIf I "Ping" the "Set Date/Time" I get an response error "Error in response: 503 Ping Failed".
Then you probably have something wrong in your network configuration. Explain how this device is connected to the rest of your network including switches or any other devices in this network and the IP addresses of your router.
Also include a screenshot of your network settings page.
Quote from: Rick on May 12, 2022, 10:42:52 PMI can not find a place on the controller that shows you what time it thinks it is?
Did you look on the Status page?
Rick
Thank you for the information - still not sure why the "Ping" is not working (other "Pings" on other internet connections on Falcon Controller page work) but all seems to be fine with the Time/Date. :)
Quote from: Rick on May 16, 2022, 10:37:15 AMstill not sure why the "Ping" is not working (other "Pings" on other internet connections on Falcon Controller page work)
Without screenshots of your network configuration and an explanation of your configuration, all we can do is to guess and send you down rabbit holes
Viper16
I am having the same issues. I manually add the date/time, save it, and have to manually start my scheduled show. It goes off a the scheduled time and a timer kills the Falcon. It boots back up and acts like the time/date is lost. Brand new CR1225 battery.
Still tinkering on it. Will do some more digging and let you all know what I come up with. I am one build behind from the current.
Viper16
I reseated my battery and was able to get it to hold time when power was removed. The scheduling is very clunky and wi-fi'ing into it is extremely painful (slow/disconnects).  With scheduling, my question is, if the power is lost and resumes, can't seem to the scheduling to auto start.
Viper16
#7
Hey Rick and designers, I am on build #20. The battery is working, but is only maintaining the time when the power was pulled.
This is when I manually set the time and save it, say I cut the power at 11:20pm when I resume power, I check the time and it shows the same date and time from when power was last killed.
breese
Quote from: Viper16 on October 07, 2022, 04:51:26 PMHey Rick and designers, I am on build #20. The battery is working, but is only maintaining the time when the power was pulled.
My controller (F16V4) is doing the exact same thing...
breese
What is real interesting is even with the battery installed and not keeping time when power is removed or rebooted...
Over an hour or so the clock starts loosing minutes.
schbrownie
I'm having the same issue.
From my computer, I'm able to ping time.google.com and get a valid response.
From the Falcon (F16v4, build 21), I get an error when attempting to ping.  (Error in response.  503 ping failed)
Both devices are connected via ethernet to the same router and back out to the internet through the same cable modem.
Any ideas?
(My show freezes at least once per night... could this be contributing to the issue?)
breese
NTP settings will not affect freezing issues.
As for the NTP time setting, you need to set a correct NTP server and Activate Internet Access.
Here is a screen shot of mine and it works now.....
Do not use my IP address for the NTP Server.
Rick
I was also getting what appeared to be random freezing of my show and was not connected to internet. I UNCHECKED the "Access Internet" box on the bottom of the "Settings" page (it was trying to update the time from the internet) and this solved my "freezing" problems.
Still have clock problems with my F16V4 running latest updates, no internet connection.
ldlammers
Was using F16V4 to control my show.  A more experienced user visited during my most challenging evening where my show froze/crashed 10 times.  Uggh.  She suggested I switch to xSchedule on my laptop to run the show.  Figured it all out before bedtime that night.  Ran a long ethernet cable out to one of my 5 controllers to get onto the show network, and had zero trouble from that point on.  Having to the laptop run the show was not as convenient as using a controller, but was super reliable and I had no issues with the F16V4 clock losing time.  Suggest you consider the same.
Quote from: ldlammers on February 01, 2023, 11:53:56 AMHaving to the laptop run the show was not as convenient as using a controller
If you have an FPP based controller (or a stand alone FPP device), then you do not need a dedicated laptop.
UDP error by Poporacer
July 15, 2024, 03:39:36 PM
do I need license for my picap New? by Poporacer
July 15, 2024, 03:35:02 PM
Audio Issue with Pi Zero 2 W by robbiet
July 14, 2024, 12:07:12 PM
USB (and other) issues on Pi Zero 2w by zaicik
July 14, 2024, 04:20:33 AM
Multiple text effects cause re-render by dkulp
July 13, 2024, 08:44:07 AM
FPP led Panel Troubleshooting. by Poporacer
July 12, 2024, 09:29:56 AM
output controller by JonD
July 12, 2024, 09:29:07 AM
Looking for SRx2 V5... by darylc
July 11, 2024, 05:54:34 PM
FPP 8.0 by colonelcline
July 11, 2024, 04:05:15 PM
SMPTE timecode by k6ccc
July 11, 2024, 10:36:03 AM
