Total Members: 16900
Latest: Mr Tinker
New This Month: 16
Total Topics: 16992
Most Online Today: 158
Guests: 81
Total: 81
DDP or E1.31
Started by bowhunter3125, December 05, 2024, 06:35:27 PM
bowhunter3125
I have a Baldrick 8 port controller hooked to a Falcon F16v4, the controller is  DDP only controller, I at first set the Baldrick output on FPP to DDP however none of the lights would work, when i set it to E1.31, I now have control over the lights, i am assuming this is ok? but i noticed tonight that during testing all my lights off the baldrick worked fine weather testing from the controller or from the PI, but when i run a sequence, only 14 of the 20 RBL's will light up. i checked the sequences, all seem fine when viewing them in Xlights, Am i missing something?
Sounds like configuration. What do you have inside your RBL? What is the config in xLights? What does the config say in FPP?
bowhunter3125
in xlights i have it set at 1 string 20 pixels then when i had the string on a falcon i had group count at 12, but now that i have it coming from the Baldrick i am unable to set the group count.
Quote from: bowhunter3125 on December 05, 2024, 10:04:03 PMthe Baldrick i am unable to set the group count
Group Count is a function of the controller, just like Null Pixels. It sounds like the Baldrick might not support a Group Count?
Quote from: bowhunter3125 on December 05, 2024, 10:04:03 PMin xlights i have it set at 1 string 20 pixels then when i had the string on a falcon i had group count at 12,
How did that even work? 20 pixels is not evenly divisible by 12?
Not Baldrick specific, but group count exerience.  I have 12 Boscoyo Pixelaria all daisy chained on one port.  Each Pixelaria has 5 nodes in each.  In xlights I set up as 12 nodes with and group count of 5 in the controller.  No success then set it as 60 pixels with a group count of 5 and thought that would take care of everything, but it did not.  Appears that just impacts xlights sequencing since I still have to indicate on the controller that I have a group count of 5.  Sounds like something similar to your use with the RBLs.
Quote from: jnealand on December 06, 2024, 08:58:23 AMAppears that just impacts xlights sequencing since I still have to indicate on the controller that I have a group count of 5
This setting in xLights is a Controller setting and you have to upload the controller config from xLights for it to take effect in the controller.
bowhunter3125
Quote from: Poporacer on December 06, 2024, 08:26:33 AM
Each puck is treated as a singke pixel in xlights, buy under co troller connections you set the group to 12 cause each puck is 12 led's.  I have 9 rbl bulbs that are 9 pixels but group count is 9 cause unhsve 9 pixels in each bulb.
bowhunter3125
I got it figured out, forgot to change the universe count from 512 to 510
Cheap Amazon pixel controller by MikeKrebs
Today at 08:10:55 PM
Interactive Mini golf using FPP? by MikeKrebs
Today at 08:05:33 PM
Light Elf Bluetooth IP65 Laser by Kap10G
March 22, 2025, 12:45:02 PM
HA MQTT plugin for single model by s1godfrey
March 20, 2025, 08:21:46 PM
Virtual Display not working? by dkulp
March 19, 2025, 11:45:01 AM
March 18, 2025, 06:00:53 PM
March 18, 2025, 04:38:32 AM
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
K16A-B Issue by nolatron
March 15, 2025, 01:52:26 PM
