LATEST RELEASE:  FPP 9.3 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/9.3
Total Members: 17107
Latest: water-j
New This Month: 31
New This Week: 18
Total Topics: 17187
Most Online Today: 1843
Guests: 295
Total: 296
F16V4 with WS2811 24v - Flickering
Started by tonymain, August 14, 2025, 01:05:50 AM
tonymain
Hi!
I have a F16V4 powered with the external power mode with a 12v power supply.
I have a WS2811 24v strip powered with a 24 power supply. Only the data cable goes from the board to the strip.
When I start up everything I have a a lot of flickering on the strip. If i disconnect the data cable the flickering stops.
I'm new to this so I probably just made some simple misstake that someone here can help me with?
Flickering can mean the lights are not getting enough power, the extension cable is too long, or not using the correct wire gauge.
How many lights are in the light string?
How long is the extension cable from the controller to the first light?
How long is the strings total length?
What gauge of wire are you using?
Is the flickering worse when the lights are white? (White uses more power)
What is the voltage of the light string at the very end?
You might need to do some power injection or possibly need to install a signal booster (F-Amp).  A signal booster will amplify the data signal and prevent flickering.  It does not look like the Falcon F-Amp will support 24v, but I think RayWu carries a 24v version.
Quote from: tonymain on August 14, 2025, 01:05:50 AMHi!
You _must_ connect ground too
Can't connect to Falcon F16v5 by nealr48
Today at 09:49:08 PM
Setting on a F48V4 blue by breese
Today at 04:50:36 AM
Video on Xligths by breese
Today at 04:48:05 AM
P5 Matrix: image corrupt only when playing from playlist. by warsome
November 13, 2025, 10:53:00 PM
Falcon F16v4 - WS2811 LEDs - One LED is always red by torfkop
November 13, 2025, 12:28:03 AM
Freeze Up by MikeKrebs
November 12, 2025, 08:02:15 PM
Readout realtime pixel status over HTTP or websocket by efiten
November 12, 2025, 08:03:55 AM
virtual matrix goes out after 3.20 mins by mrgimmeone
November 12, 2025, 06:07:23 AM
Singing faces extra pixels? by Petrey
November 11, 2025, 05:39:45 PM
i did something wrong I think by lightsonwass
November 11, 2025, 04:22:58 PM
