Total Members: 16847
Latest: dennis93
New This Month: 25
New This Week: 7
Total Topics: 16948
Most Online Today: 132
Guests: 90
Total: 92
API commands returning errors
Started by mcsketchy, August 30, 2023, 06:56:15 PM
mcsketchy
I'm getting errors when using some api commands in FPP 7.0. These are commands and error below:
192.168.0.22/api/sequence/Halloween.fseq/start/60 or 192.168.0.22/api/sequence/Halloween/start/60
Notice: Undefined variable: settings in /opt/fpp/www/api/controllers/sequence.php on line 132
Notice: Trying to access array offset on value of type null in /opt/fpp/www/api/controllers/sequence.php on line 132
{"status":"OK","SequenceName":"Halloween.fseq","startSecond":"60"}
192.168.0.22/api/sequence/Halloween.fseq or 192.168.0.22/api/sequence/Halloween
Notice: Undefined variable: sequence in /opt/fpp/www/api/controllers/sequence.php on line 23
Notice: Undefined variable: sequence in /opt/fpp/www/api/controllers/sequence.php on line 24
Limonade
Page not found:
Not found: .fseq
The sequence appears in the array as expected
I also have a general question; is there a command to start a sequence that isn't recommended for testing only. I can't put this sequence into a separate playlist because I'd like to pause a playlist, play standalone sequence, and then resume the original playlist. If I put the standalone sequence into a playlist, I won't be able to resume the original playlist where it was paused.
kcammack
Quote from: mcsketchy on August 30, 2023, 06:56:15 PMI also have a general question; is there a command to start a sequence that isn't recommended for testing only. I can't put this sequence into a separate playlist because I'd like to pause a playlist, play standalone sequence, and then resume the original playlist. If I put the standalone sequence into a playlist, I won't be able to resume the original playlist where it was paused.
Did you ever figure this out?
darylc
Quote from: kcammack on January 03, 2025, 03:28:57 PM
Check out the insert playlist immediate API call, eg http://192.168.34.234/api/command/Insert%20Playlist%20Immediate/test
K2-Pi-Servo by breese
Today at 01:47:06 PM
FPP 8.4 released! by lrhorer
Today at 09:09:58 AM
January 14, 2025, 05:54:32 PM
January 14, 2025, 11:55:25 AM
January 14, 2025, 07:42:55 AM
January 12, 2025, 10:40:05 AM
xLights.org forum registration waiting for approval for several months. by darylc
January 11, 2025, 12:42:54 AM
FPP sequence fade by CaptainMurdoch
January 10, 2025, 08:19:33 AM
Combining multiple shows (models, sequences, etc.) into a single xLights show by JonD
January 09, 2025, 07:41:31 PM
F8 Distro Board and 36V power supplyu by JonD
January 09, 2025, 12:04:31 PM
