Total Members: 16969
Latest: eglass90
New This Month: 7
Total Topics: 17043
Most Online Today: 191
Guests: 137
Total: 137
K128D to control LED panels on Pi-FPP
Started by BrianA, December 09, 2024, 03:11:59 PM
BrianA
Trying to see how to (or if I can) configure the K128D to be a player with other devices as remotes. On my other FPPs, there is a 'tab' for "E1.31 / ArtNet / DDP / KiNet" where other devices are configured, but no such tab on the K128d.
Am I missing something here?
Basically, I want to change my player from a Pi-FPP to the BBB-FPP on the k128d so I can use the fm output off it.
Quote from: BrianA on December 09, 2024, 03:11:59 PMTrying to see how to (or if I can) configure the K128D to be a player with other devices as remotes.
Yes, you can.
Quote from: BrianA on December 09, 2024, 03:11:59 PMOn my other FPPs, there is a 'tab' for "E1.31 / ArtNet / DDP / KiNet" where other devices are configured, but no such tab on the K128d.
It is there, depending on what version of FPP you are running, you might have to be in advanced UI mode, but you really should let xLights handle that for you
BrianA
Yep, I hadn't enabled the advanced UI.
I am using Xlights for pushing configs, but I didn't see where I specify the player vs remote. Manual is a bit sparse searching for 'remote' or 'master'
Quote from: BrianA on December 09, 2024, 04:08:06 PMbut I didn't see where I specify the player vs remote.
It is covered in the Manual. Maybe it wasn't written well enough?
Quote from: BrianA on December 09, 2024, 04:08:06 PMManual is a bit sparse searching for 'remote' or 'master'
Since there is no Master mode, you probably wouldn't find anything, there is a Player mode. But there are 130 instances of "Remote" in the manual, that doesn't sound sparse? There is even a section that covers the different types of networks that you might need to configure in order for the Player/Remote to communicate with each other.
BrianA
That I see in the UI, but I don't see how to set that from within XLights. It looked like you were saying I should set that from there.
Quote from: Poporacer on December 09, 2024, 03:34:06 PMIt is there, depending on what version of FPP you are running, you might have to be in advanced UI mode, but you really should let xLights handle that for you
I take it that it is indeed done from within the FPP UI.
Quote from: BrianA on December 09, 2024, 05:19:57 PMbut I don't see how to set that from within XLights.
No, you set the mode inside the Gui of FPP
Quote from: BrianA on December 09, 2024, 05:19:57 PMI take it that it is indeed done from within the FPP UI.
Bingo
Honestly, I wouldn't recommend doing much more than driving the pixels on the K128.  The single core Beagle already struggles to handle 128 strings of pixels if many of the strings long.    It really doesn't give the CPU much time left to be sending out e1.31/DDP packets, etc...  I'd recommend grabbing a Pi and run in a master/remote setup so the network stuff can be offloaded to the Pi (and maybe sound) and let the K128 just handle pixels.
QN8066 FM Transmitter by Poporacer
Today at 10:04:30 AM
Plugin for scoreboard data from node red by sharkboy005
July 16, 2025, 03:06:54 PM
July 16, 2025, 03:05:09 PM
July 14, 2025, 05:26:28 AM
July 13, 2025, 10:54:02 PM
E fuse api by Jrbrown
July 12, 2025, 08:06:48 PM
July 11, 2025, 06:11:50 PM
July 03, 2025, 03:57:56 PM
July 02, 2025, 03:10:16 PM
July 02, 2025, 11:38:48 AM
