Total Members: 16848
Latest: ramblingmcgregor
New This Month: 26
New This Week: 8
New Today: 2
Total Topics: 16948
Most Online Today: 164
Guests: 62
Total: 62
Weird date / time issue
Started by rodjclark, November 04, 2024, 09:37:46 PM
rodjclark
I am having issues with the date / time in my FPP. I believe this is the first time I've had this.
My controller is an old F16V2R, but I don't think that's the issue. It looks to be something weird with the FPP software that I updated to v8.2 a week or so ago when I setup. I do not have an RTC connected to the Raspberry Pi.
At 20:30 yesterday - Saturday the 4th of November 2024 FPP was showing Friday the 6th September 2024. If I change the Time Zone and reset it, it updates correctly to Australia's East coast. If I change the NTP server it seems to make no difference. I'm an IT guy, but not very experienced with FPP, and after any clue as to where to look and how to debug.
Thanks,
Rod
There is a current NTP issue listed on github.
https://github.com/FalconChristmas/fpp/issues/2031
There have been several NTP issues with 8.x this year.  Especially on upgraded units from prior versions.
I am running 8.2 OS 2024-10 on a Pi4 and NTP is working fine.  It pulls time correctly from my internal time server.  I did have to install the OS twice.  You might try installing 8.2 over the top of what you have, if that does not work, a fresh new image of 8.2 and restore from backup might resolve.
You do not need to specify a timeserver unless you have a specialized need for it. Delete your Time server.
Quote from: Poporacer on November 05, 2024, 06:54:04 AMYou do not need to specify a timeserver unless you have a specialized need for it.
Having your FPP instance NOT having Internet access, and having a NTP server on the local network would be one of those specialized needs for it.
Quote from: k6ccc on November 05, 2024, 07:22:14 AMHaving your FPP instance NOT having Internet access, and having a NTP server on the local network would be one of those specialized needs for it.
That is correct, but the OP was using time.google.com, that wouldn't fall into that category, LOL
rodjclark
Quote from: JonD on November 05, 2024, 04:14:09 AMThere is a current NTP issue listed on github.
Thanks, I'll check out the link and look at reinstalling. Painful as I've never had issues in the past.
To be clear for other commenters, I've tried multiple NTP servers and their IP addresses. The only reason I tried them was because it didn't work after I upgraded and the default setting (blank) was no longer working.
Thanks,
Rod
I did modify my ntp.conf file at one point.  If the above does not resolve, you might take a look at your tos minsane value.
https://falconchristmas.com/forum/index.php?topic=16907.msg135257#msg135257
rodjclark
Thanks to those trying to help.
I installed the latest FPP/OS update as there had been a release since I updated and made the ntp.conf change suggested without luck.
I'll see about doing a full wipe/reinstall, but I have a low level of confidence that that will help.
Can I, via the UI, choose to install an earlier version? I'm tempted to go back to 7.x as that was working.
Regards,
ROd
K2-Pi-Servo by breese
Today at 01:47:06 PM
FPP 8.4 released! by lrhorer
Today at 09:09:58 AM
January 14, 2025, 05:54:32 PM
January 14, 2025, 11:55:25 AM
January 14, 2025, 07:42:55 AM
January 12, 2025, 10:40:05 AM
xLights.org forum registration waiting for approval for several months. by darylc
January 11, 2025, 12:42:54 AM
FPP sequence fade by CaptainMurdoch
January 10, 2025, 08:19:33 AM
Combining multiple shows (models, sequences, etc.) into a single xLights show by JonD
January 09, 2025, 07:41:31 PM
F8 Distro Board and 36V power supplyu by JonD
January 09, 2025, 12:04:31 PM
