LATEST RELEASE:  FPP 9.3 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/9.3
Total Members: 17167
Latest: Marsvinrex
New This Month: 21
New Today: 4
Total Topics: 17246
Most Online Today: 330
Members: 3
Guests: 27
Total: 30
How to setup and configure controllers in xLights I have a few.
Started by cais2108, November 06, 2025, 11:16:30 AM
cais2108
I have a few controllers that I would like to properly set up and configure before the christmas season that way I am able to host a functional and expansive show. I have the Falcon F16V5, the Falcon F16V4 with 16 expansion ports(32 total), and the SR x4 V4 from falcon as well. I also tried to flash my Raspberry Pi4 with FPP earlier this year but was unable to figure out how to correctly do that and if I need the pi-hat. I'm using xLights and can connect these controllers to a wifi network if needed however I would prefer that I don't run them on wifi if possible. Could anyone give me some basic setup tips? For the previous shows that I have run, I only used one controller and kept it in Player mode while swapping the SD card when I need to change/add files. Thanks
You don't need a pi-hat. FPP can be the player for your other controllers.
Put your xLights pc, FPP and your controllers plugged into a switch. No wi-fi needed.
Burn the RPi image that you downloaded from https://github.com/FalconChristmas/fpp/releases/tag/9.3 on a sdcard. Insert card into RPi, turn it on and in about 10 minutes, visit FPP.local in a browser,
In xLights, go to the controller tab. Click Discovery. Did it find your "stuff". If not, set the device manually filling in the vendor, model and IP address.
Now you can
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI also tried to flash my Raspberry Pi4 with FPP earlier this year but was unable to figure out how to correctly do that and
This might help.
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI'm using xLights and can connect these controllers to a wifi network if needed however I would prefer that I don't run them on wifi if possible.
Is there a reason that you do not want to use Wi-Fi?  But in any case, this might help
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI only used one controller and kept it in Player mode while swapping the SD card when I need to change/add files. Thanks
The Falcon line of controllers "can" be used as players or remotes, but it is VERY limited. Most people prefer to use an FPP based Player (typically a Raspberry Pi)
Kulp K16 Max Network Setup by dkulp
December 07, 2025, 05:00:48 PM
SRx4 pixel count by Poporacer
December 07, 2025, 04:22:02 PM
Enable/disable schedule through API or button by MikeKrebs
December 07, 2025, 01:04:13 PM
Lynx Express reflash by zwiller
December 07, 2025, 11:56:04 AM
How to start a playlist in FPP using a Midi or OSC by nightowl
December 07, 2025, 10:47:37 AM
FPP Connect kicks off FPP Schedule by ukkeef
December 07, 2025, 03:12:20 AM
FPP SMTPE plugin by nightowl
December 07, 2025, 12:55:32 AM
Bad data on daisy chained SRX1-PSU by davidr236
December 06, 2025, 03:36:21 PM
Kulp K16A-B RJ45 differential receiver output pixel count specs? by aggieNick02
December 06, 2025, 11:20:02 AM
BRP Voting Plugin - Allow others to vote for your songs! by Barkers Random Projects
December 05, 2025, 09:33:10 PM
