Total Members: 17219
Latest: Ash
New This Month: 18
Total Topics: 17305
Most Online Today: 250
Guests: 194
Total: 195
How to setup and configure controllers in xLights I have a few.
Started by cais2108, November 06, 2025, 11:16:30 AM
cais2108
I have a few controllers that I would like to properly set up and configure before the christmas season that way I am able to host a functional and expansive show. I have the Falcon F16V5, the Falcon F16V4 with 16 expansion ports(32 total), and the SR x4 V4 from falcon as well. I also tried to flash my Raspberry Pi4 with FPP earlier this year but was unable to figure out how to correctly do that and if I need the pi-hat. I'm using xLights and can connect these controllers to a wifi network if needed however I would prefer that I don't run them on wifi if possible. Could anyone give me some basic setup tips? For the previous shows that I have run, I only used one controller and kept it in Player mode while swapping the SD card when I need to change/add files. Thanks
You don't need a pi-hat. FPP can be the player for your other controllers.
Put your xLights pc, FPP and your controllers plugged into a switch. No wi-fi needed.
Burn the RPi image that you downloaded from https://github.com/FalconChristmas/fpp/releases/tag/9.3 on a sdcard. Insert card into RPi, turn it on and in about 10 minutes, visit FPP.local in a browser,
In xLights, go to the controller tab. Click Discovery. Did it find your "stuff". If not, set the device manually filling in the vendor, model and IP address.
Now you can
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI also tried to flash my Raspberry Pi4 with FPP earlier this year but was unable to figure out how to correctly do that and
This might help.
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI'm using xLights and can connect these controllers to a wifi network if needed however I would prefer that I don't run them on wifi if possible.
Is there a reason that you do not want to use Wi-Fi?  But in any case, this might help
Quote from: cais2108 on November 06, 2025, 11:16:30 AMI only used one controller and kept it in Player mode while swapping the SD card when I need to change/add files. Thanks
The Falcon line of controllers "can" be used as players or remotes, but it is VERY limited. Most people prefer to use an FPP based Player (typically a Raspberry Pi)
FPP MIDI plugin installed but wont trigger Playlist by MikeKrebs
January 20, 2026, 08:48:20 PM
FPP 9.5-1 causing 192-168-8-1 for most WiFi IP by Sawdust
January 20, 2026, 01:52:27 PM
pocketbeagle2 - OLA with PRU DMX output by s-light
January 20, 2026, 01:22:17 AM
Long term issue with FPP on Beagle by Sawdust
January 18, 2026, 11:50:52 PM
FPP driving P10 and also pixel outputs - several options by k6ccc
January 18, 2026, 05:49:34 PM
LoRa plugin. Is it worth pursuing in 2026 by dkulp
January 18, 2026, 05:18:50 PM
SRx4 Long Range Quad SmartReceiver by tbone321
January 13, 2026, 03:32:30 PM
Pixel Port by LedMutt
January 13, 2026, 12:57:46 AM
Peace Stake material by LedMutt
January 12, 2026, 12:15:36 AM
Forbidden Error Port 80 by darylc
January 11, 2026, 10:24:48 PM
