LATEST RELEASE:  FPP 8.1 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/8.1
Total Members: 16582
Latest: wacamoe
New This Month: 20
New This Week: 11
New Today: 3
Total Topics: 16621
Most Online Today: 65
Guests: 41
Total: 41
FPP/Pi Issue
Started by ramiroelliot, September 30, 2024, 10:23:02 PM
ramiroelliot
Hey everyone,
second season with my light setup and I'm perplexed at an issue that I discovered recently. I'm running a Pi model 4 through wifi controlling 2 Falcon F16v4's with an ethernet cable.
I went to setup my halloween show last week and realized I couldn't login to FPP. I restarted the Pi and the falcons with no luck. I noticed that my Pi wasn't putting out any ethernet lights or getting an IP address. I did some troubleshooting, and finally put my SD card in an older Pi model 2. I connected this to my router directly and was able to get an IP address, ethernet lights, and login to FPP directly.
I thought it was a bad Pi, so I got a new one and reinstalled FPP v8. I tried to login to the FPP network (as well as the default 192.168.8.1 address) after installation to set it up and the network never showed up. Thought maybe a bad card, so I reinstalled FPP on a new card, and still nothing. I can't even hard wire it, because I get no ethernet lights or IP address.
I have no idea what the problem is. None of my network settings have changed since the summer when I ran my show without issue. I appreciate any input or guidance anyone has.
AAH
The 192.168.8.x network range is a slightly odd range. 192.168.0.x is far more common.
Can you plug the pi and sd card in question directly into a router and try connecting to it via http://fpp.local assuming you haven't changed the hostname. If you have changed it then you should be able to log into your router and see it.
If you have a fresh install of FPP (being Version 8 ) then you will either need to connect to it a router so that an IP address is assigned via DHCP or alternately look on your wifi for a network called FPP and log into that and then setup the IP and everything else in order to be accessible from your laptop/router wireless network.
Quote from: AAH on October 01, 2024, 01:45:25 AMThe 192.168.8.x network range is a slightly odd range.
The FPP tether feature uses the 192.168.8.x range by default.
Quote from: ramiroelliot on September 30, 2024, 10:23:02 PMI can't even hard wire it, because I get no ethernet lights or IP address.
The pi4 should be displaying link lights on the ethernet port if there is an active connection there.  If Pi4 is working and you do not have link lights, the OS is not booting up properly, or there are issues with the network cable.  Are you using a SD extender cable?  I have had a few of those go bad.  Might try a different type of SD card.  Unlikely two Pi4s would go bad.
co-universes.json does not exist keeps showin up in log by eatumup
Today at 10:25:25 PM
Pixels flickering when playing directly from XLights by Poporacer
Today at 08:22:57 PM
Install New FPP by PittFan
Today at 08:05:55 PM
Xlights FPP Connect Issues by Poporacer
Today at 07:43:34 PM
K40 Network port stopped working by Joepat
Today at 07:19:17 PM
PiCap V2 & DMX by jnealand
Today at 04:19:03 PM
Composite analog video output on Pi 4 / FPP 8.1 by scsi
Today at 01:10:17 AM
FPP->HinksPix by MikeKrebs
October 08, 2024, 09:12:13 PM
Video uploads not working. by bciarcia
October 08, 2024, 08:32:23 AM
F8-PB V1.2 by Poporacer
October 08, 2024, 07:17:18 AM
