Total Members: 15698
Latest: kronescharles
New This Month: 16
Total Topics: 15828
Most Online Today: 45
Guests: 24
Total: 26
Matrix issues with F48v4
Started by Wodrith, December 06, 2021, 08:27:39 PM
Wodrith
I'm hoping my description can be concise and figure out this issue.
I have a F48v4 and the old F48 in a show. The old F48 is supporting some props I'm not currently issues so I will focus on the F48v4.
I have the old smart receivers operating in dumb mode (so no chaining). Connecting to these are a few matrixes that all exhibit the same behavior, but I'll focus on the largest one since it's more pronounced.
The matrix is 4160 pixels. This is split up on 8 ports (two smart receivers in dumb mode). That makes 520 pixels per port and it is wrapped 13 times. This makes the matrix 40 pixels tall. (I'm starting from the bottom, going to the top, so vertical strings).
Slow moving effects hav no issues and look great. Images look how I would expect. Everything looks like it is wired correctly and tests on full white look solid with no issues.
Problems. Fast effects that go up and down look fine. Fast effects that go left to right have big issues. I can see what looks like 8 boxes ( on the smaller matrix with two ports, I see two). These 8 boxes all show the exact behavior, the first part looks right, the second half looks like it is showing the last frame... making a non smooth transition.
I'm using E.131 data. Sequences are at 40fps.
What should I check first?
rudybuddy
Not sure if this is the case when operating the receivers in normal mode, but I believe the V1 Smart Receivers will not work with the newer V4 products and you would need the newer V2 receivers.
Padre Tiempo
Rudybuddy is correct, the v1 smart receivers will only work in "dumb" mode with the F48v4.
Wodrith
Quote from: Wodrith on December 06, 2021, 08:27:39 PMI have the old smart receivers operating in dumb mode (so no chaining).
What I have found out with about 10 hours in zoom. The F48v4 may be the issue.
I validated every piece of my setup works
  • Network switch
  • Network switch port
  • Pi3b+
  • Cat 5 between controller to switch
  • Cat 5 between F48 and smart receivers (in dumb mode)
  • smart receivers (switched out both white and blue boards)
  • Validate power injection is sufficient
Getting pretty frustrated, I swapped the matrix from my F48V4 to my F48V1 and the issue went away.
The only thing I cant validate is swapping out a F48v4 for another one as I just have the one.
Today at 07:54:22 AM
March 24, 2023, 04:04:06 PM
March 24, 2023, 10:44:49 AM
March 23, 2023, 11:06:14 AM
March 22, 2023, 11:11:59 AM
March 21, 2023, 05:53:50 PM
March 21, 2023, 09:37:23 AM
March 16, 2023, 05:25:46 PM
March 15, 2023, 01:17:55 PM
March 13, 2023, 09:29:28 AM
