Total Members: 17237
Latest: Routhhurwitz
New This Month: 1
Total Topics: 17328
Most Online Today: 287
Most Online Ever: 8375
(February 21, 2026, 03:58:04 AM)
Guests: 199
Total: 199
HUB75 P4 1/10 Matrix
Started by Powerdata44, March 09, 2026, 08:51:00 AM
Powerdata44
Hello,
This is my first time posting about this topic. I bought four HUB75 RGB outdoor matrix panels (P4, 1/10 scan) and connected them using an Adafruit RGB Matrix HAT Bonnet with a Raspberry Pi 3B+.
I installed the FPP firmware on the SD card for the Raspberry Pi and followed several YouTube tutorials. In the videos everything works for them, but I cannot get it working on my setup.
I have re-watched the tutorials many times and checked everything carefully. In the Raspberry Pi settings I configured a 2×2 grid and set the panel chains as shown in the videos. However, the panels still do not light up.
I also tried using a Raspberry Pi 5, but I have the same problem — the LED matrices still do not turn on.
Has anyone experienced this issue or knows what might be wrong with my setup?
Thank you.
AAH
I don't know what the current state of FPP is but the Pi5 may not work. Some features of FPP weren't working in FPP last I saw.
Can you post screenshots of your FPP setup and and also photos of the rear of the panels showing the wiring of the IDC16 connector and also the model number of the panels.
Quote from: AAH on March 09, 2026, 03:54:28 PMSome features of FPP weren't working in FPP last I saw.
And what features were those? As far as I know they were all working.
Powerdata44
 Here are two photos of my Matrix layout showing which socket the Raspberry Pi should be connected to (the IN port).
These Matrix are 64x32.
I'll upload a screenshot of my FPP settings later as well. Hopefully these photos help.
AAH
Quote from: Poporacer on March 09, 2026, 05:10:09 PM
I can't find the post anywhere but I was reasonably sure that Dan Kulp had posted somewhere that there was still integration issues with panels on a Pi5 with FPP.
How are you powering the panels?  You might want to take a screen shot of your FPP configuration for the panels.
AAH
Quote from: Powerdata44 on March 10, 2026, 03:04:19 AMHere are two photos of my Matrix layout showing which socket the Raspberry Pi should be connected to (the IN port).
The model number has information that says the panels aren't 64x32.
P4-1921-80x40-10S-S2.0. P4 panel, 80 pixels x 40 pixels, 1/10th scan rate.
Powerdata44
Quote from: AAH on March 11, 2026, 05:58:58 PM
Hmm, I said 64x32 because when I previously set up the matrices using Python on the Raspberry Pi (for a status board project) with some help from ChatGPT, the matrix details were set as 64x32. That's why it stuck in my mind.
At that time Python was controlling all four matrices and it worked fine. I just thought I would try using the same matrices with FPP after seeing some examples on YouTube.
You could just count the leds on one side and verify the number? Likely not the problem with nothing showing up on the panels though. However, the whole parameters of your panels could be the problem.
Have you tried doing just one panel?
Stupid question department.  Are you connecting to the correct port (input vs output) on the panels?
Can you update 3b+ to 9.5.3? by SCUBA
April 12, 2026, 01:50:41 PM
Moving Head Color by SCUBA
April 12, 2026, 11:00:42 AM
FPP 9.5 on Linux by coyoteray
April 11, 2026, 05:49:56 PM
VSA to FPP conversion program by Scaregroundspdx
April 02, 2026, 01:42:54 PM
Limitations of Matrix Display by conceptpl
March 27, 2026, 03:22:53 AM
F16V4 IP Address by MikeKrebs
March 23, 2026, 08:21:32 PM
Help troubleshooting by aaronhess
March 19, 2026, 09:21:24 AM
Can't seem to get my network connections right. by Poporacer
March 16, 2026, 11:21:39 AM
F16v3 Expansion bad resistors by 2Couyon
March 13, 2026, 04:03:59 PM
HUB75 P4 1/10 Matrix by k6ccc
March 13, 2026, 08:45:44 AM
