Total Members: 16972
Latest: Talor978
New This Month: 10
New This Week: 5
New Today: 3
Total Topics: 17043
Most Online Today: 2179
Guests: 76
Total: 76
No RPIW281x on FPP 7.5?
Started by Steve, May 15, 2024, 02:38:43 PM
Change you cape config to pihat dpipixels...
Now do the port 1 and port 2 act appropriately?
Steve
I've removed the DPIPixels eprom and installed the PiHat............ Good news it lights using the test option and performs as expects, so the issue is with the DPIPixels eprom config. I assume the PiHat option will not allow me to plug-in a 3.5mm jack socket to get the audio output?
I'll now remove the PiHat and try the DPIPixels again..... will report shortly
Thanks all
Steve
I've just removed the PiHat Eeprom and re-installed the DPIPixels Eeprom, guess what........ if i set channel 1 with the same settings (although limited to x50 leds, as I'm yet to install the licence) it does not control the lights, but if I change channel 3 down to 2 pixels it responds as expected.
Steve
#18
I've since found another post on here that confirms this problem, looks like:
Port 1 on the Pi-Cap is port 3 on DPIPixels
Port 2 on the Pi-Cap is port 24 on DPIPixels
So, where does this leave me....
Well I assume that I could continue with DPIPixels and add the licence so i can add 300 pixels to a single channel and use the audio output jack on the Pi for my sync'ed audio
or
Should I use PiHat, but can i output the sync'ed audio?
Thoughts and comments very much welcomed, thank you.
Quote from: Steve on May 20, 2024, 01:19:43 PMand installed the PiHat
Which Pi-Hat? That is the important question. There are almost 1400 reported FPP devices that are using a Pi-Hat and you are the first that I know of that is reporting this behavior.
Quote from: Steve on May 20, 2024, 01:47:23 PMif i set channel 1 with the same settings
I assume that you mean Port 1? Same Settings? What does that mean? What start channel and what pixel count?
Quote from: Steve on May 20, 2024, 01:47:23 PMit does not control the lights
So are you saying that no lights light up what so ever? Or just the lights connected to port 1?
Quote from: Steve on May 20, 2024, 01:47:23 PMbut if I change channel 3 down to 2 pixels it responds as expected.
So you have Ports 1 and 2 and 3 configured for 50 pixels and no lights work, but by simply reducing the pixel count on port 3 to 2 pixels, ports 1 and 2 start working?
Quote from: Steve on May 20, 2024, 02:19:36 PMI've since found another post on here that confirms this problem
Can you provide a link to that please?
Quote from: Steve on May 20, 2024, 02:19:36 PMWell I assume that I could continue with DPIPixels and add the licence so i can add 300 pixels to a single channel
Port, not channel
Quote from: Steve on May 20, 2024, 02:19:36 PMShould I use PiHat, but can i output the sync'ed audio?
You can use either method. Like I mentioned earlier, you can use the PiHat with the RPIW28x protocol and still sync your audio. You will just need a Soundblaster adapter.
You need this one. 2 port PiHat using DPIPixels
I am on:
FPP Version:    8.x-master-275-gbc771770
Platform:    Raspberry Pi (Pi 3 Model B)
FPP OS Build:    v2024-03
Steve
Hi Poporacer,
I'm using a Falcon PiCAp, the other post i found is here https://falconchristmas.com/forum/index.php?topic=16236.msg131080#msg131080
Steve
#22
Quote from: MikeKrebs on May 20, 2024, 09:05:37 PMYou need this one. 2 port PiHat using DPIPixels
I am on:
Interesting......... I'm using a Falcon PiCap's first set-up is on a Pi3B the same as you and the second setup uses a Pi4
Two questions,
1. How do i purchase a licence as i'm using over 50 pixels on each port? - Now sorted!
2. Does this allow me to use the onboard audio using the 3.5mm jack socket on the Pi or do I need a USB adapter, i need to output the music that the lights are synced to?
Thanks Mike
Quote from: Steve on May 21, 2024, 01:44:08 PMI'm using a Falcon PiCAp, the other post i found is here
And did you see that the problem was due to the user installing the wrong EEPROM type and it was fixed when installed correctly?
Quote from: Steve on May 21, 2024, 02:02:11 PMDoes this allow me to use the onboard audio using the 3.5mm jack socket on the Pi
Yes, that is what using the DPI Pixel protocol allows.
Quote from: Steve on May 21, 2024, 02:02:11 PMdo I need a USB adapter
Not if you are using the DPI Pixels, but many people do not like the quality of the sound output from the Pi. (But there are several that love using it as well)
Plugin for scoreboard data from node red by Mark_M
Today at 07:51:12 AM
QN8066 FM Transmitter by aaronross
July 18, 2025, 04:27:42 AM
Scoreboard Plugin by sharkboy005
July 16, 2025, 03:05:09 PM
July 14, 2025, 05:26:28 AM
July 13, 2025, 10:54:02 PM
E fuse api by Jrbrown
July 12, 2025, 08:06:48 PM
July 11, 2025, 06:11:50 PM
July 03, 2025, 03:57:56 PM
July 02, 2025, 03:10:16 PM
July 02, 2025, 11:38:48 AM
