Total Members: 16967
Latest: Jrbrown
New This Month: 5
Total Topics: 17041
Most Online Today: 152
Guests: 120
Total: 122
Abnormal conditions, received bridging data while sequence is running
Started by Paulanator, May 18, 2025, 04:02:35 PM
Paulanator
I am using a Falcon Pi Hat and have set it up for angel wings with 5 buttons. I have that all working great.
My goal is to have the wings part of the show from the master controller and when someone pushes a button the wings stop the main sequence and run local static sequence for about 1 minute. That is working great. Then it goes back to the main show after the minute.
I am running the Pi Hat as a player, and it receives data from the show, then when a button is pushed the wings run the sequence for the button pushed.
The only little issue is that when the button is pushed the pi gets the error: Abnormal conditions, received bridging data while sequence is running.
If it seems to be working, is this ok to ignore?
I have seen a video where someone put a relay in on his setup, but mine seems to be working, but I was just concerned about any other issues I might be causing.
Paul
Quote from: Paulanator on May 18, 2025, 04:02:35 PMI am running the Pi Hat as a player, and it receives data from the show
If it is a Player, that means that it is the "conductor" of the show and nobody should be telling him what to do. But you configured your Pi-Hat to also listen to the Show player. This is NOT a normal condition and that is the reason for the error message.
You probably want the Pi-Hat to be a Remote (AKA Listen for instructions from the show player). And then when a button is pressed, play the sequence that you want it to play and when it is done, revert to listening to the show player.
Quote from: Paulanator on May 18, 2025, 04:02:35 PMIf it seems to be working, is this ok to ignore?
Possibly.
Paulanator
Falcon 16v4 configuring to smart receivers by Jack S
Today at 01:17:17 PM
E1.31 Bridge Mode - Crash by AAH
July 12, 2025, 09:19:22 PM
E fuse api by Jrbrown
July 12, 2025, 08:06:48 PM
July 11, 2025, 06:11:50 PM
July 03, 2025, 03:57:56 PM
July 02, 2025, 03:10:16 PM
July 02, 2025, 11:38:48 AM
fpp-Capture by ericjforman
July 02, 2025, 11:37:53 AM
June 25, 2025, 08:46:47 AM
June 18, 2025, 07:13:49 AM
