Total Members: 16932
Latest: encore
New This Month: 7
Total Topics: 17018
Most Online Today: 117
Guests: 92
Total: 94
Remote Player with two players the same network
Started by SCUBA, December 06, 2024, 07:05:59 AM
SCUBA
This issue may have been resolved earlier for other versions of FPP.  I'm currently running version 8.3.1 on three FPP:
1) a stand alone FPP (in Player mode) setup to display several videos to inform folks of radio station freq, and other messages.  It is on the show wireless network for simple stuff like status checking, potential new video additions etc.
2) Master FPP that runs the lightshow on two networks: wireless and Eth0.  the Eth0 port goes to a switch that communicates with 12 SanDevice controllers.
3)A FPP in Remote mode that should be sync'd to the master.  This Pi is connected to a projector that runs videos only that is associated with the Master FPP sequences.  Input/output tab is empty.
ISSUE: the remote FPP will not run the videos.  Can someone please recommend, in some detail, how I should configure the various pi's.  Currently the remote Pi has all of the sequence and media files uploaded.  And the file names do match the Master FPP playlist.  The attachments are screen shots of the Master FPP multisync page and the network page.
If your remote is only playing videos, then you do NOT want the sequences or audio files on that device. And the video on the remote has to be named to match the AUDIO source of the sequence with the exception of the extension.
There were no attachments
SCUBA
Human Error on the attachments.
Thanks for the reply Rick.  The "Video only" is a stand alone.  Not a remote.  it's set to "player".  Works fine as a sign.  FPP label is 'TVFPP'
The Remote needs to sync'd with the master.  But it will not play the media video associated with the master sequence.  it "sees' both player FPP. Remote label is 'FPPUpstairs'.
All these files are associated with the MasterFPP.
SCUBA
I completely shutdown the FPP for the standalone pi.  Still doesn't work.
Quote from: SCUBA on December 06, 2024, 10:45:33 AMThe Remote needs to sync'd with the master.
Just to clarify things, a device can ONLY be a Player or Remote (Bridge mode for non-FPP based controllers.
There is no Master mode, that was deleted a long time ago because of the confusion)
A Remote will sit idle until some outside source tells it what to do.
A Player will start/stop and coordinate your schedule. If there are remotes, then the Player can be configured to output the appropriate data to each remote. (each remote might need a different type of data so you have to configure the different types if needed)
Quote from: SCUBA on December 06, 2024, 07:05:59 AM3)A FPP in Remote mode that should be sync'd to the master.  This Pi is connected to a projector that runs videos only that is associated with the Master FPP sequences.  Input/output tab is empty.
Are you sure that the Outputs Tab is empty? There are a ton of errors in the MultiSync page that says otherwise!
Quote from: SCUBA on December 06, 2024, 10:45:33 AMAll these files are associated with the MasterFPP.
Can you post a screenshot of your File Manager page on your FPPUpstairs FPP showing your Video page?
Just a FYI, after you upload the Screenshot, you can insert it so that it can be visible on the page.
Quote from: SCUBA on December 06, 2024, 12:15:44 PMI completely shutdown the FPP for the standalone pi.  Still doesn't work.
LOL, one has nothing to do with the other.
SCUBA
Thanks Rick,
I use the name of the FPP as Master-FPP4...it runs in player mode not remote or master.
Yes the remote output page is quite empty.
Quote from: Poporacer on December 06, 2024, 12:50:44 PMA Player will start/stop and coordinate your schedule. If there are remotes, then the Player can be configured to output the appropriate data to each remote. (each remote might need a different type of data so you have to configure the different types if needed)
How do I configure the FPP's?
I thought the errors were due to having loaded the sequences on to the remote.  I removed the sequences and I don't get any error messages.
screenshot file of FPPUpstairs file Manager:
You cannot view this attachment. You cannot view this attachment. You cannot view this attachment.
Sorry I wasn't able to insert a visible screenshot (Mac?) How?
What about "pixel overlay Models"
Quote from: SCUBA on December 06, 2024, 03:07:50 PM.it runs in player mode not remote or master.
Like I said, there is NO Master mode.
Quote from: SCUBA on December 06, 2024, 03:07:50 PMYes the remote output page is quite empty.
I don't think it was at the time of the multiSync screenshot, but that is fine, it isn't there now.
Quote from: SCUBA on December 06, 2024, 03:07:50 PMHow do I configure the FPP's?
We will get into that later.... you are actually close right now.
Quote from: SCUBA on December 06, 2024, 03:07:50 PMI thought the errors were due to having loaded the sequences on to the remote.
No, those errors were because there were outputs enabled, but yes, you do not want sequences on an FPP that is only playing videos.
Quote from: SCUBA on December 06, 2024, 03:07:50 PMscreenshot file of FPPUpstairs file Manager:
Thank you so much for providing the needed information! It really helps. I forgot one screenshot, post a screenshot of your playlist page from your Main Player.
Quote from: SCUBA on December 06, 2024, 03:07:50 PMSorry I wasn't able to insert a visible screenshot (Mac?) How?
After you upload your image, you will get another option to insert
Quote from: SCUBA on December 06, 2024, 03:07:50 PMWhat about "pixel overlay Models"
What about them? I don't think I mentioned them?
SCUBA
Rick on the Mac you just get a file link when you press insert.
never mind about the pixel overlay models.
correct about the remote output page
You cannot view this attachment. The playlist I use is 2024 Show long. ~118 entries
Quote from: SCUBA on December 07, 2024, 02:00:45 PMRick on the Mac you just get a file link when you press insert.
Are you sure? This was from a Mac
Quote from: SCUBA on December 07, 2024, 02:00:45 PMThe playlist I use is 2024 Show long. ~118 entries
I need to see the actual playlist
SCUBA
Rick, Please see the attachment as requested:  You cannot view this attachment.
Thank You.  BTW: did you see the other posting I uploaded about the error message I was getting?  These files play well on a third party video player.  I also used  Handbrake to re-format the files as MP4 (they were MP4 originally).
Thanks again
John
SCUBA
Rick figured out the upload issue... the file name had a leading "space".  All good!
How did you get your MP4 files onto FPP in the first place if there was a space in the original file name?
I think the problem is due to your naming with the space. It looks like you might have created the sequence with a file name for the audio that had a space in the beginning. Linux (the operating system behind the scenes in FPP) handles special characters differently than Windows computers and special characters in file names have been a problem so the developers have gone to great lengths to try and "fix" people's mis-use of special characters and this caused the problem.
I would go to your mp4 files on your computer and delete any special characters in them to include leading spaces. And then open each sequence and change the audio source to the correct fixed file.
Delete all mp4s from both the player and remote.
FPP Connect and upload your sequences and media.
I am curious why all of your audio files for your sequences are mp4? Does your player output video as well?
SCUBA
Quote from: Poporacer on December 08, 2024, 08:52:44 AMHow did you get your MP4 files onto FPP in the first place if there was a space in the original file name?
correct....Great call
