Total Members: 15305
Latest: PBAH89
New This Month: 8
New This Week: 6
New Today: 2
Total Topics: 15258
Most Online Today: 99
Members: 5
Guests: 55
Total: 60
Translucent Durable Waterproof Fabric
Started by xtremedew, July 09, 2021, 01:39:17 PM
xtremedew
Hi All,
I have an idea to build out some 2'x2'x2' cubes of PVC and wrap them with some type of translucent fabric, but wanted to reach out to see if anyone came across anything. My thought is to put a RGB flood light inside, and then wrap the top and sides.
I looked at some vinyl materials, but it doesn't shine light through that well. There are other materials are available, but I am not sure how durable "outdoor-wise" they will be with the elements.
Thanks in advance,
Dave
SteveRatcliffe
Is this to make glowing cubes, or to protect the floods from the weather?
SCUBA
I used a shower curtain from Target.  Two versions "white" and "translucent".  If I was you I'd use the translucent for the display and scotch tape aluminum foil to the back and bottom of the cube (if it's on the ground).  The cube should gloss nicely.
SCUBA
BTW: you don't need a flood light, wrapping the LED's around a Styrofoam ball will work nicely and you can " imprint" several colors onto the cube's sides.
Play with it a bit, send a photo when you're done!
Here is a link to some plastic I used for a project a few years ago:
https://www.tapplastics.com/product/plastics/plastic_sheets_rolls/led_ligh_panel/598
It worked very well.  It comes in a roll, but flattened out easily.  I do like SCUBA's shower curtain idea - and a lot cheaper than the link above (but I needed something semi-stiff).
SCUBA
also if you use PEX-A tubing it may look homogenous.  PEX-A is translucent, use 3/4" stuff.  PEX-A (not PEX-B) is not very ridged.  2' should be ok
xtremedew
Thanks All. Yes is is for making glowing cubes, not to protect the floods.
I do like the shower curtain idea. Family member mentioned raincoat material also. I'll give some ideas a shot!
JonB256
I use shower curtain as my projection screen in a bedroom window. Halloween and Christmas. Cheap projector, driven by a RasPi hdmi running Standalone.
Trigger media or playlist from incoming artnet/sACN by info@trans-mission.tv
Today at 12:39:02 PM
FPP Advanced Features Key has been used. by tfmacz
Today at 12:17:47 PM
DIY voucher request by steve123
Today at 09:14:32 AM
Written documentation for Differential Receivers v2.01 by JonD
Today at 09:04:50 AM
Docker Container - No Multisync Discovery by EricD
October 04, 2022, 10:51:15 PM
Unable to reconnect to BBB after network config by Stoshx
October 04, 2022, 06:33:05 PM
WTB F16v4 by Poporacer
October 04, 2022, 02:31:40 PM
F16V3s for Sale by Manuelpereyra78
October 04, 2022, 12:33:36 PM
October 04, 2022, 09:54:36 AM
House preview - full screen icon missing by JonD
October 03, 2022, 06:03:37 PM
