Total Members: 15500
Latest: baggiorobertson1
New This Month: 8
New This Week: 36
Total Topics: 15596
Most Online Today: 68
Members: 8
Guests: 23
Total: 31
FPP Custom HomeMade PiHat for Pi B RevB with 26 Pin GPIO Header
Started by tfmacz, September 20, 2022, 11:44:21 PM
tfmacz
I Have a number of Raspberry Pi B with the 26 pin GPIO Header.
I will hand wire a custom Pixel String PiHat to fit these.  The GPIO Header does not have GPIO19 for the second string.  It is not convenient to put both models on a single string.  They a only 100 Pixels each but some distance apart.  How can I change the Pixel string output pin in the GPIO Header to something that is available on the 26 Pin Header?
If I buy a 2 pin DPIPixel-24 license can I change the pins there?
Ted
bloojoop
the standard output type uses hardware PWM which is only available on GPIO 18 ad 19.  Cannot get a second port using that output type.  Using the DPIPIXEL output type, you can define your pins by building a custom virtual EEPROM that defines what pins are used for which ports.  There likely would be instructional help in the fpp github page regarding custom eeproms.  I don't think DPIPixels was test on a PI B and it is very dependent on timing and uses the video frame buffer and the GPU so it may not even work on a PI B.  If it did and you wanted to use that output type, it would require a license to enable more than 50 pixels per port.
--Ron A.
tfmacz
Could you provide a bit of help in where to look for info on creating a "custom virtual EEPROM"?  If I can get it to use a different pin I can test if it might work at 50 pixels.  If so It would be worth the $5 to buy a 2 port license to test further.
Ted.
bloojoop
It's a bit technical for sure and I have not done it. I would search in the github repository... there are some docs samples about eeprom structure.
--Ron A.
tfmacz
Thanks.  I have been searching through the git repository.  I have found the eeprom.txt explination of the eeprom structure.  it's the extra code that I am trying to decipher.  You suggest the gpio pins are in there somewhere.
tfmacz
As it turns out.  If I use the DPIPixel output type. Pay for an 8 port license.  I can use at least 6 ports with the standard GPIO header assignments.  So far, 300pixel strips are behaving.
Raspberry PI 4 won't connect to WIFI by rbarry1068
Today at 11:18:38 AM
Sequence freeze by Poporacer
Today at 11:04:54 AM
Today at 10:40:18 AM
Today at 09:57:03 AM
Today at 06:43:26 AM
December 02, 2022, 11:15:17 PM
Bacground sequence by darylc
December 02, 2022, 07:34:21 PM
Fpp 6.2 ui password by darylc
December 02, 2022, 07:30:33 PM
Updating from FPP Version 3.5.4 to the latest FPP 6.1 by Poporacer
December 02, 2022, 07:07:09 PM
schedular wont do anything ever by spudgunman
December 02, 2022, 05:52:55 PM
