LATEST RELEASE:  FPP 7.2 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/7.2
Total Members: 16349
Latest: bweber
New This Month: 0
Total Topics: 16238
Most Online Today: 92
Guests: 61
Total: 63
FPP Ignore GPIO triggers outside show hours
Started by robbiet, September 27, 2023, 09:29:09 AM
robbiet
Hi. Does anyone know how to disable GPIO triggers outside of scheduled show hours?  My Pi stays on 24/7, so need a way to disable triggers during the day. These are motion sensors so I've thought about putting them on a relay to power off during the day. Is there a way to just configure in FPP?
#1
In the past I have used two GPIO triggers.  A primary trigger that is turned on/off during show hours and a secondary trigger for the play button.  When the primary trigger is enabled the secondary trigger works.  Out of schedule the primary trigger is disabled which prevents the secondary trigger from working.  I have seen someone ask this question before and it seems like someone had a better response, but not finding it now.  If someone else doesn't answer you might search for it in the archives.
#2
I found the topic I mentioned above
https://falconchristmas.com/forum/index.php?topic=16036.15
Quote from: CaptainMurdoch on January 03, 2023, 01:47:05 PMIf you are still wanting to enable/disable the gpio input via the scheduler, you can try running a script that calls the 'fpp' command to switch the gpio pin from input to output.  If it is set to output, then any button presses should be ignored until you run the fpp helper again to set it back to an input.
/opt/fpp/src/fpp -G GPIO_NUMBER Output
/opt/fpp/src/fpp -G GPIO_NUMBER Input
/opt/fpp/src/fpp -G 17 Output
/opt/fpp/src/fpp -G 17 Input
The case is sensitive on the Input/Output keywords.  The GPIO_NUMBER is the number on the FPP GPIO Input config page.
robbiet
Great. I will give this a try. Thanks for digging!
FPP 7.3 sound blaster issue by breese
Today at 04:17:42 AM
FPP 7.3.1 sending mixed colors? by CaptainMurdoch
Today at 12:43:22 AM
Falcon Player Network Setup by MikeKrebs
December 05, 2023, 09:37:37 PM
P5 Screen by LedMutt
December 05, 2023, 08:10:20 PM
Remote Falcon Plugin issue by Poporacer
December 05, 2023, 07:58:04 PM
Visualizer File by Poporacer
December 05, 2023, 05:17:00 PM
Color Order by Poporacer
December 05, 2023, 05:13:57 PM
Abnormal Condition Error by Poporacer
December 05, 2023, 04:27:34 PM
Channels not working by CeP
December 05, 2023, 06:44:21 AM
F8-B+ locking up BBB by CeP
December 05, 2023, 05:14:10 AM
