Total Members: 16900
Latest: Mr Tinker
New This Month: 16
New Today: 2
Total Topics: 16992
Most Online Today: 223
Guests: 173
Total: 173
Pi 4 Ethernet issue with Cisco Routers
Started by greg, January 28, 2025, 10:06:03 AM
greg
Not really FPP related but may help some people trouble shoot if they come here looking for answers.  This past season I was having trouble with on of my PI's It was a Pi 4 (dont recall version of fpp) it became very intermittent.  Did all the normal troubleshooting with no good results.  Replaced the Pi with a 3b+ thinking the 4 could have been dying.  Finished the season no problem.  Onto post season, setting up a brand new pi 4 and experienced similar issues.  eventually got things setup and working so began some testing.  a few days not problem, today (not changing anything the last two weeks) not working, wireless working no problem no wired ethernet.  Did normal troubleshooting cables etc. Put a Pi3 back inline and worked perfectly.  Did a little digging online, apparently the Pi4's experience intermittent connection with some cisco routers and of course the only thing I didn't check as it had worked on all other devices.  pulled out a small Linksys router and viola both PI4's now working.  I was able to duplicate creating the problem several times and each time I went back to the linksys I had no issues.  So for those of you that may com across this issue this may help you narrow down your problem.
Were you supplying the Pi 4 with enough power? Then need significantly more power than the 3B and I have seen many strange problems that were resolved with the correct power supply.
greg
Yes it worked fine for about 2 weeks.  (initially upon setup it was intermittent) today nothing changed and it didn't work.  Powering via PiCap v2 from a meanwell ps
Quote from: greg on January 28, 2025, 07:48:19 PMPowering via PiCap v2 from a meanwell ps
We have seen a LOT of the PiCaps that do NOT supply enough current to effectively run a Pi 4 even though the PSU is more than large enough.
greg
Thanks, I didn't know that.  I will say that it did work with the other switch after changing back and forth several times.  However I will investigate this a little further.  I did do a search online and found others having problem with cisco switches and I confirmed I was also experiencing the same issues.  I did try powering the pi with a known working wall-wart that came with the other pi4 I had and it behaved the same way so i ruled that out.
Interactive Mini golf using FPP? by Mark_M
Today at 03:50:07 AM
Cheap Amazon pixel controller by MikeKrebs
March 23, 2025, 08:10:55 PM
March 22, 2025, 12:45:02 PM
March 20, 2025, 08:21:46 PM
March 19, 2025, 11:45:01 AM
March 18, 2025, 06:00:53 PM
March 18, 2025, 04:38:32 AM
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
K16A-B Issue by nolatron
March 15, 2025, 01:52:26 PM
