Total Members: 16873
Latest: jameman12
New This Month: 12
Total Topics: 16970
Most Online Today: 139
Guests: 78
Total: 78
F16V4 no fan control showing in settings
Started by mgholland, December 30, 2024, 02:25:38 PM
mgholland
F16V4 with a 4 pin Noctua NF-A6x25 PWM fan connected in the case.
but cannot find the fan control on the web page under setting.
where do you find the fan Settings.
The controller shows it's on build 33 but I have upgraded the firmware today to 34 and then to 36 but still says build 33 and no Fan settings.
The controller did say the firmware was upgraded and needed to reboot on both versions.
thanks for any help.
You are still on firmware build 33.  I have had issues upgrading the latest versions over the web interface, and have had to use the SD card method to upgrade the last few versions.
I have fans on my F16v4, but I don't remember where the settings are.  I took my display down last Saturday when we had 50F weather, and none of my controllers are running to get a print screen.  If someone does not post, I will drag one out and let you know.
Quote from: JonD on December 30, 2024, 02:52:13 PMI have had issues upgrading the latest versions over the web interface, and have had to use the SD card method to upgrade the last few versions.
I have seen/helped dozens of people that were unable to update via the web interface but were successful in the SD card method.
Quote from: mgholland on December 30, 2024, 02:25:38 PMwhere do you find the fan Settings.
It looks like there might have been some confusion on how this actually works, and people were making changes that they should not have made, but that is pure speculation on my part.
By default, the fan will constantly run at 1500 RPM. There is a setting (now somewhat hidden) to allow the user to set a temperature that will cause the fan to ramp up. If you want to set that value (although there are warnings in doing so) You have to type in Controller_IP/advanced.html and in that page uncheck the "Disable Action On Temp Thresholds" and then you will have the settings visible on the Settings page.
mgholland
Quote from: Poporacer on December 30, 2024, 04:17:58 PM
Thanks, I will give this a try today.
mgholland
Quote from: Poporacer on December 30, 2024, 08:20:42 PM
Thank you that worked by unchecking Disable Action On Temp Thresholds. The Fan settings now show up under the Settings Tab
mgholland
Has anyone ever used heat sinks on the processor of any Falcon controllers.?
Like the ones you can get for the Pi and stick them on.
just curious if this would help to protect the processor at all, I ask because I had an F16v2 Red go down on me and the processor was to hot to touch. I think I heard a crackle while sitting there checking it out.
Have not tried.  My cases are enclosed and the entire box is pretty warm.  I use a https://www.wiredwatts.com/ipv-1115 vent and point the fan to blow out to keep it from sucking in snow in the winter.  A heat sink might be better than nothing, but if it is that warm, it would be probably be better to get some air exchanging from outside.  The aussies would be a much better source to get advice from though.
K32 only the pixels stopped outputting by tetleytealeaf
February 06, 2025, 02:03:40 PM
SPixels broken in version 6 and upwards by dkulp
February 04, 2025, 02:52:30 PM
FPP stopped working by crookedpriority
February 03, 2025, 10:45:17 AM
Setting up a wired on demand show on Pi/ FPP to push a show to Falcon Controller by breese
February 03, 2025, 04:54:44 AM
F16V4 Expansion Board Half of the board stop lighting up. by onlineshopper
February 03, 2025, 03:08:47 AM
Overlay Matrix: write more than one pixel at a time ? by niemy
February 02, 2025, 03:35:16 PM
FPP Spixels bug by Colg
January 31, 2025, 02:52:05 PM
