Total Members: 16896
Latest: nolatron
New This Month: 12
Total Topics: 16987
Most Online Today: 159
Guests: 56
Total: 58
Combining multiple shows (models, sequences, etc.) into a single xLights show
Started by grant.simpson, January 09, 2025, 12:10:55 PM
grant.simpson
I manage a fleet of several hundred parade floats and many of those floats have multiple units (think of a train where you have the locomotive, passenger cars, and a caboose, each is a unit).  Right now, they are all independent controllers each running their own xLights show.  I am planning on tying all of the controllers together (adding a FPP player if needed) so I can run a synchronized show across the entire float and have effects run across the entire float.  Is there a way to take multiple xLights shows (sequence and models) and combine them.  I'm sure there would be a lot of clean-up work after the process with channel numbers and everything else, but it would likely be less than the work of re-creating the models and sequences from scratch.
You could certainly export each model and import it into another sequence.  You could also import the sequencing over once the model is there.  Not sure if there is an easier method.
Quote from: grant.simpson on January 09, 2025, 12:10:55 PMI'm sure there would be a lot of clean-up work after the process with channel numbers
Not if you let xLights auto-config your controllers ;)
grant.simpson
I've found where to export the models under the "tools" menu but I have not found where to import the models into a new sequence.
You don't need to export them. Here is how I think your flow should be.
I would create a new folder for your full train by copying the xlights_networks.xml and xlights_rgbeffects.xml from one of your "cars" and pasting it into your new folder.
1. Go to the layout page and right-click on the layout screen and select Import models/previews/groups from one of the "cars" that isn't in this current layout.
2. Select all that you want to import and repeat #1 until all the cars are in your layout
3. Create a new sequence with the song, and save it
4. Click on the Import>Import Effects and select the sequence file for the first car and select Auto-Map
5. Continue #4 until all the effects from all the cars are now in the one sequence.
You may need to be on the layout tab instead of the sequencer tab for the import option to show up.  @Poporacer's suggestion sounds easier though.
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
K16A-B Issue by nolatron
March 15, 2025, 01:52:26 PM
F16V5 and SRx1 v5 by jkp
March 15, 2025, 07:19:44 AM
March 14, 2025, 09:17:01 AM
FPP 8.4 Back up by Jradical
March 13, 2025, 05:38:18 AM
March 12, 2025, 05:39:00 PM
March 11, 2025, 09:19:08 AM
K2-Pi-Servo - xLights Visulizer by dkulp
March 06, 2025, 09:20:30 AM
DIYLIGHTANIMATION shutting down Feb 28, 2023 by jnealand
March 02, 2025, 10:58:12 AM
