Total Members: 16934
Latest: Promotiondrile
New This Month: 9
New This Week: 4
Total Topics: 17020
Most Online Today: 84
Guests: 79
Total: 79
Installe Tenda W311U mini wireless USB
Started by jnealand, September 29, 2013, 01:48:05 PM
I am failing on step 1 and 2 of the following.  Not being a linux guru I assume since the apt directory is not found that means has been removed from the FPP distribution.  If so, how do I download and install a driver?  Or should I give up and just install something you guys support, but I cannot find a list of what is supported with the FPP so other than materdaddy's favorite edimax I am at a loss.  Just trying to use what I already have in-house.  I also have a Dlink DWA-140 which supposedly works  per the list here http://elinux.org/RPi_USB_Wi-Fi_Adapters
Installing the Tenda W311U Mini Wireless USB Dongle
Jun 30, 2012
This install guide was completed on the latest stable release of Debian Squeeze, but it should work on later releases, such as Wheezy. This guide will give a step by step overview of how to install the Tenda W311U MiniWireless USB Adaptor.
Requirements: Make sure you have a decent power supply for the Pi (we use 2000mA adaptors to stop any low power cut-outs), in addition to a USB hub. Like most wireless dongles, the Tenda adaptor requires more power than the Pi USB ports can provide, so it will need to be plugged into a powered hub.
Also, make sure that you are connected to the internet via a LAN cable.
1. Firstly, we need to check that the OS we are using has a 'non-free' component:
sudo grep non-free /etc/apt/sources.list
Which should reveal:
deb http://ftp.uk.debian.org/debian/ squeeze main non-free
Or similar. If this is not the case, you've really buggered something up (or you're super smart). Anyway, if it doesn't say that, you'll need to change it to the above (or your local Debian ftp server), or simply format your SD card and start again with the OS.
2. We can now install the Ralink drivers.
Change the directory to where we want the drivers to go:
cd /etc/apt
And install them:
sudo apt-get install firmware-ralink
3. OK so we've installed the drivers, plug the dongle into a spare port on the USB hub and we'll query it with the lsusb command:
lsusb
This should reveal a list of the installed usb devices, including the dongle:
Bus 001 Device 005: ID 148f:3070 Ralink Technology, Corp. RT2870/RT3070 Wireless Adapter
4. As a double check, we can check the system log to see if it's registered the dongle.
dmesg
This will check the system log, and the most recent log should be the successful installation of the wifi dongle:
usb 1-1.3: new high speed USB device number 5 using dwc_otg
usb 1-1.3: New USB device found, idVendor=148f, idProduct=3070
usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.3: Product: 802.11 n WLAN
usb 1-1.3: Manufacturer: Ralink
usb 1-1.3: SerialNumber: 1.0
cfg80211: Calling CRDA to update world regulatory domain
usb 1-1.3: reset high speed USB device number 5 using dwc_otg
ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Registered led device: rt2800usb-phy0::radio
Registered led device: rt2800usb-phy0::assoc
Registered led device: rt2800usb-phy0::quality
usbcore: registered new interface driver rt2800usb
Cool, it's now been installed! Now we need to install a network manager to get on-line! There's a variation of network managers to choose from. But we have selected gnome as an example:
5. Let's just make sure everything is up to date:
sudo aptitude update
6. Next lets install the network manager:
sudo aptitude install network-manager-gnome
It should come up with a warning saying that you will use SD card space, just say yes.
7. After it's installed, it's probably worth restarting your Pi.
Now unplug your LAN and boot your Pi.
Start up the GUI with:
startx
You should now have the network manager in the corner of the screen, next to the time. Click on this and connect to your wireless network!
Easy Peasy!
Author: Neil Ronketti
MyKroFt
until the web GUI gets released, all wireless config has to be done by hand by editing the /etc/network/interfaces file.
If you want to leave it DHCP, all you have to do is edit the network SID and password
Tony
So much to learn, maybe I should concentrate on sequencing.  Of course I have never done that before until the crush gets closer.  LOL.
JonB256
Quote from: MyKroFt on September 29, 2013, 05:08:39 PM
Tony
Tony, I tried editing the /etc/network/interfaces file. Put in my SSID and password. This is with the "WiPi" USB wireless. It seemed to work pretty well, but seriously confused my router and I began to get Duplicate IP warnings and it never showed the correct MAC for the WiPi. The RaspPi would correctly announce the IP address on startup and sometimes I could run the Web interface from the IP address, but not always. It was like I could only used 2 of the 3 available addresses (192.68.0.10 and 192.68.0.145 and 192.68.0.234). The .10 address would almost always work. When it didn't was the times I'd get "Duplicate IP" address errors.
Currently, the WiPi is not plugged in and everything is fine.
Jon
MyKroFt
Your wifi usb dongle and the built in eth interface should have completly different mac addresses.  That is how DHCP address are assinged is via MAC address.
a ifconfig on the CL will show you the mac addresses of your interfaces.
the 192.168.0.10 is a static fallback ip.  It will always be there unless you take it out of the interfaces file.  It is there for when you have it hooked up to a switch and no DHCP server is avail and you dont have any interfaces set as static.
I will look into the current network settings page that is in the dev brance and see what I can do for ppls having trouble setting ip addresses etc.
Tony
To many things to do I ordered an Edimax wireless adapter today from NewEgg.  $9.99 plus free shipping.
gdyrdave
 I just received the Edimax nano wifi usb and installed it. Prior to installation I edited the interfaces file to reflect my networks ssid and psk. Put the wifi in and restarted. No joy. The lsusb list shows it is there. DPitts basically it is plug and play. Anything I am not doing  or doing wrong? Is it possibly that I am using a hex psk as opposed to ascii ?  FYI
Dave
MyKroFt
ssid and passwords are case sens - wpa mode
also make sure they are inside the quotes
Tony
gdyrdave
Yes the case is correct and are within quotes.
Dave
gdyrdave
If I enable WPA I have to increase the size of the password. What if I disable wep/wpa and make it open system?
Dave
MyKroFt
I use WPA-Personal on my router(s) and it connects just fine....
Password I use is only 10 chars long (passphrase) not hex keys
Tony
Materdaddy
I use the edimax and used wpa_cli to configure it.
Remove the crap from /etc/network/interfaces for wlan0.
Boot using wired ethernet.
Use wpa_cli when plugged into regular ethernet: http://www.ronnutter.com/raspberry-pi-adding-wifi-wpawpa2-using-wpa_cli/ (I think I've sent you this link 4 times now. ;))
Once you have both interfaces working, you can save it (in that tutorial) and reboot with only the wireless plugged in from then on.  Pay attention to the IP address you get when using wpa_cli as it should be the same after a reboot (assuming you're using a router with a respectable DHCP implementation).
gdyrdave
Hi Mat,
  I know you sent that link to me. I did not work for the other wifi dongle I bought. I bought the Edimax because it was basically plug and play. I will try changing the wep key to ascii in the router.
Dave
neilric99
does the wpa_cli software allow you to setup as wep as well as wpa?
Materdaddy
Quote from: neilric99 on October 02, 2013, 08:27:44 AM
Yes, wpa_cli configures wpa_supplicant which supports basically all wireless security types (afaik).
You will run a scan, and it'll tell you what encryption all found networks are using.
