Total Members: 16898
Latest: Kap10G
New This Month: 14
Total Topics: 16990
Most Online Today: 159
Guests: 113
Total: 113
F8 Distro Board and 36V power supplyu
Started by Xenia, October 07, 2018, 03:05:38 PM
Xenia
Will the F8 Distro board V1.02 handle a 36V power supply.  I want to power two runs of 3 30W floods through the board.  Max draw should be about 3 amps per outlet.
Thanks,
Randy
JonB256
Quote from: Xenia on October 07, 2018, 03:05:38 PM
Thanks,
Randy
No problem. The fuses are 5amps on each output.
David Pitts
The resistors for fuse indication are ~960 ohms so leds would burn bright.
Xenia
Thanks Dave.  Someone else running these suggested turning the power supply down to 30 Volts.  Also I doubt I run these at more than 50% power at any given time.  They arrive tomorrow so I will be able to do some experimenting before mounting them on the park pavilion.
JonB256
#4
Quote from: Xenia on October 07, 2018, 11:36:08 PM
Running the flood lights at 50% power won't affect the brightness of the small LEDs. As long as you are will to accept their brightness and probable short lifespan, the board will distribute 36v. (The LED resistor value was picked with an expectation of 24v max)
I also have other vendor distro boards without LEDs so I didn't really consider that.
David Pitts
The resistor was selected for 12V or less.
grant.simpson
Thanks for posting this Dave, I'm starting to use a good number of 24v LEDs and am going to be using these distro boards so I will just take the indicator lights as "may or may not" be accurate.  Is not a problem in my case.
Quote from: grant.simpson on January 09, 2025, 11:51:38 AMThanks for posting this Dave, I'm starting to use a good number of 24v LEDs and am going to be using these distro boards so I will just take the indicator lights as "may or may not" be accurate.  Is not a problem in my case.
You responded to a 6 year old post.  I have not seen David post on this forum in a very long time.  David is unlikely to see this.
Light Elf Bluetooth IP65 Laser by Kap10G
Today at 11:45:04 AM
HA MQTT plugin for single model by s1godfrey
March 20, 2025, 08:21:46 PM
Virtual Display not working? by dkulp
March 19, 2025, 11:45:01 AM
March 18, 2025, 06:00:53 PM
March 18, 2025, 04:38:32 AM
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
K16A-B Issue by nolatron
March 15, 2025, 01:52:26 PM
F16V5 and SRx1 v5 by jkp
March 15, 2025, 07:19:44 AM
Differential Board: PSU & Enclosure by hakko808
March 14, 2025, 09:17:01 AM
