LATEST RELEASE:  FPP 8.1 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/8.1
Total Members: 16582
Latest: wacamoe
New This Month: 20
New This Week: 11
New Today: 3
Total Topics: 16621
Most Online Today: 65
Guests: 49
Total: 49
Setting up FPP and Xlights to talk to PCA9685 (Servos)
Started by jce90, March 14, 2024, 04:10:43 AM
jce90
Hi everyone, I need your help please.
I am trying to add some servos to my show using PCA9685. I will be running PCA9685 from a raspberry pi. I am not sure what I am doing wrong as I am trying to test the servo on xlights talking to the raspberry pi. I have attached pictures how I set up FPP and Xlights.
Is there something I am missing?
You cannot view this attachment. You cannot view this attachment.You cannot view this attachment.
Thank you
Quote from: jce90 on March 14, 2024, 04:10:43 AMI am trying to test the servo on xlights
Do they work when testing from FPP? That should be your first testing point. If they don't work from FPP, they will not work from xLights
Quote from: jce90 on March 14, 2024, 04:10:43 AMI have attached pictures how I set up FPP and Xlights
Thank you so much, that helps a TON!
Quote from: jce90 on March 14, 2024, 04:10:43 AMIs there something I am missing?
Look in xLights and see how many channels you have your FPP configured to output? Does that look correct?
In xLights, you have your FPP configured as FPP Player Only which means that it is NOT outputting anything to local port, but it is just sending E1.31/DDP or Multisync data to OTHER devices...AKA Player only. Since this FPP is acting as a Controller, you need to tell xLights that it is going to be a controller. Did you put your servos in your layout and assign them to a controller?
jce90
Thank you for your reply. I got it to work on testing mode on FPP. My only issue is to set up xlights to talk to FPP. I have updated my controller settings but unfortunately I still can't output to lights to test my servos in the sequence. I thing I have the controller setting on xlights wrong but I am not sure what part is wrong. Thank you
Quote from: jce90 on March 15, 2024, 05:47:28 AMMy only issue is to set up xlights to talk to FPP.
It doesn't look like you are letting xLights configure FPP? You don't have FPP configured as a Controller. You probably want to set the Model as PiHat. And you probably don't want to manually configure the controller either, use the Visualizer and push the configuration.
Quote from: jce90 on March 15, 2024, 05:47:28 AMI thing I have the controller setting on xlights wrong but I am not sure what part is wrong.
Where did you get the values that you entered for the servos?
How about a screenshot of your Outputs page from FPP?
jce90
Thanks a lot for your help. I have missed the visualizer part. As soon as I added that, everything worked fine. Thank you  :)
I got these values from a tutorial found on youtube.
Quote from: jce90 on March 15, 2024, 04:35:00 PMThanks a lot for your help.
Anytime
Quote from: jce90 on March 15, 2024, 04:35:00 PMAs soon as I added that, everything worked fine. Thank you  :)
Awesome, glad it worked out!
BigBillTX
Hi- Can you share your final configuration in xLights? I have the same issue, I can move the servo manually using the 'Display Testing' but not through xLights. I know xLights can talk to FPP because I see the Status change and I get an error on FPP saying "RPIWS281x: No output pin configuration for: PiHat, Could not initialize output type RPIWS281X. Check logs for details."
#7
Do you have the inputs enabled on your FPP?
Did you install the virtual eeprom?
Quote from: Poporacer on September 09, 2024, 08:33:21 PMDid you industrial the virtual eeprom?
I believe that the word you were looking for was install.  Don't ya just love autocorrect.
Quote from: tbone321 on September 09, 2024, 09:14:43 PM
Yep! And you don't catch it.
co-universes.json does not exist keeps showin up in log by eatumup
Today at 09:30:31 PM
Pixels flickering when playing directly from XLights by Poporacer
Today at 08:22:57 PM
Install New FPP by PittFan
Today at 08:05:55 PM
Xlights FPP Connect Issues by Poporacer
Today at 07:43:34 PM
K40 Network port stopped working by Joepat
Today at 07:19:17 PM
PiCap V2 & DMX by jnealand
Today at 04:19:03 PM
Composite analog video output on Pi 4 / FPP 8.1 by scsi
Today at 01:10:17 AM
FPP->HinksPix by MikeKrebs
October 08, 2024, 09:12:13 PM
Video uploads not working. by bciarcia
October 08, 2024, 08:32:23 AM
F8-PB V1.2 by Poporacer
October 08, 2024, 07:17:18 AM
