Total Members: 16960
Latest: slotdesign
New This Month: 12
New This Week: 3
Total Topics: 17035
Most Online Today: 710
Guests: 325
Total: 325
FPP 8.4 released!
Started by dkulp, December 06, 2024, 01:08:22 PM
FPP 8.4 is released!
This release consists mostly of bug fixes as the result of digging through crash logs, bug reports, zoom room issues, etc...  The main purpose is to provide a release that rolls all the crash fixes and other bug fixes into an easy to install/use release package.
NOTE: The OS level has not changed since 8.3. There is no need to do an fppos update if coming from 8.3.
Enhancements
  • Add Advanced option to stop Colorlight outputs from being disabled if ethernet link is down when fppd starts
  • Update rpi_ws281x to support newer Pi 3A+/3B/3B+/CM3
  • Update UDPOutput to support a "blocking" mode to slow down packet output to allow slower controllers to keep up better. (Advanced UI setting)
  • Schedule Preview - mark items that will be skipped in red and note priority reason
Bug Fixes (since 8.3.0)
  • Fix crash when manually stopping playlist using ArtNet/SMPTE plugins as timecode generator
  • Fix crash using HTTP to detect some AlphaPix controllers
  • Fix pixel output on right half of K128
  • Fix crashes on SanCloud BeagleBone Enhanced due to to gpiochip label differences
  • Fix api/scripts//run
  • Fix api/events/:eventId/trigger
  • Fix failed plugin install messaging
  • Fix HDMI audio out on Pi's
  • Fix crash if efuse enable pin cannot be configured. Warn and continue, but don't crash
  • Fix a potential crash if PLAYLIST_STOPPED command preset is called
  • Fix crash if Chase/Cycle custom pattern is selected, but pattern is empty
  • Fix crash if pixel configuration or other configuration json is invalid during output setup
  • Fix tooltips on MQTT page being truncated
  • Fix some crashes with dynamic playlists that are empty
  • Fix some crashes with invalid pixel overlay model configurations
  • Fix crashes with RGBMatrix (panel hats for Pi) on older armv6 Pi's
  • Fix a crash when sending invalid WLED effect commands
  • Fix a crash if fseq file is corrupt
Installation Instructions
If you have a system running 8.x, you can go to the FPP about page (about.php) and click on the "Manual Update" button. At that point, a big green "Upgrade" bar should appear on the main status page. Click on that to start the update process. It may take a long time to upgrade. Likely 5-10 minutes. You will need to reboot after the upgrade is complete to finish the upgrade process.
For users of FPP 7.x or older, it is strongly recommended to do a full "OS Level" upgrade or re-image instead of attempting to upgrade directly from any older FPP version. There are several new features that will not work if an OS level upgrade is not done. There are two ways to do so:
  • Re-image - you can backup your 7.x configuration, create a new image, and restore the configuration.
  • In-place upgrade - this requires you to have FPP 5.5 and all the updates for 5.5 or FPP 6.x/7.x already running on the device. Download the appropriate "fppos" file to your computer. Make sure the file extension is still fppos (some browsers will rename it). Upload it to the "File Manager" on the FPP instance. Then go to the about page. Under the normal "Manual Upgrade", a new Upgrade OS button should appear. Click it and wait a LONG time. When done, it should reboot into 8.3. At that point, go to the Uploads tab of the FPP File Manager and delete the fppos file. An alternate method to do an in-place upgrade if you are only upgrading one device AND the device has internet connectivity, is to select the 8.3 fppos (download) file and then click on the Upgrade OS button. This will download the fppos file and then install it as mentioned above. This will still take a LONG time and if you are doing this on more than one device, you will essentially be downloading the same file multiple times so is probably not the best way.
NOTE: In SOME cases, the reboot will fail due to library replacement. In that case, a power cycle may be required to get it back up and running.
Selecting an image
For Raspberry Pi series use this image
https://github.com/FalconChristmas/fpp/releases/download/8.4/FPP-v8.4-Pi.img.zip
For Beaglebone Black, Beaglebone Green, PocketBeagle, and Beaglebone Green Gateway use this image
https://github.com/FalconChristmas/fpp/releases/download/8.4/FPP-v8.4-BBB.img.zip
lrhorer
I am currently running 8.4 on a system with input GPIO4 enabled on the falling edge to run a Python script.  I need to have the script check both GPIO4 and GPIO17 to see if one or both are low.  In Python, when I use
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(4,GPIO.IN)
GPIO.setup(17,GPIO.IN)
I get an error lgpio.error: 'GPIO busy' on the GPIO.setup(4,GPIO.IN) line.
Note this script runs under more conditions than only when GPIO4 is low, so I cannot merely assume GPIO4 is low.
What would be the best way to handle this?  Gpiozero also does not work.
I might not understand how Python and FPP play together but I think FPP has that pin "busy". So skip the setup and just read "the other one".
Do you have a hat installed that may be consuming pins?
You could likely run "gpioinfo" from the command line it it may show which process is consuming the GPIO pins.
lrhorer
FPP is indeed using the pin, as expected.  The problem is, I still need to be able to scan the state of the pin in the external script.  The script needs to run on the falling edge of the pin, but it also needs to examine the pin whether nor not it has been called by FPP.  It runs under various situations, including when FPP calls it, as well, and it needs to know the status of the pin whether it has been called by FPP or not.
Quote from: lrhorer on January 15, 2025, 03:16:51 PMFPP is indeed using the pin, as expected.  The problem is, I still need to be able to scan the state of the pin in the external script.  The script needs to run on the falling edge of the pin, but it also needs to examine the pin whether nor not it has been called by FPP.  It runs under various situations, including when FPP calls it, as well, and it needs to know the status of the pin whether it has been called by FPP or not.
Personally, I would use node-red instead of a script and have FPP issue a MQTT status when the pin is pressed and let node-red do all the logic including calling back to FPP's API to cause FPP to do things.  This comes with the added bonus of a visual workflow rather than having to re-read/learn the script each time to troubleshoot or modify it.
lrhorer
#6
The script does not interact with FPP in any way.  It runs under various situations, one of which is a power or fuse failure, which is indicated by GPIO4 transitioning from around 3V to 0V.  After the script is spawned, it collects various data such as CPU usage, memory usage, temperature, etc.  If requested by the name used to call the script, or if an important situation exists it sends emails and / or texts.  Otherwise it responds per the name used to call the script.
If both GPIO4 and GPIO17 are low, then there is a main power or main fuse failure.  If only GPIO4 is low, then it is a failure of the fuse feeding the string.  If neither are low, then power is OK. (Obviously in this latter case, the script was not called by FPP.) Here is the script so far:
#! /usr/bin/python3
# pi_monitor.py
# Scan / print the health of a Raspberry Pi and
# report any issues to the phone or email list
import psutil, subprocess, email, smtplib, ssl, SendMessage
from time import sleep
from sys import argv, exit
from os import uname
from gpiozero import CPUTemperature
Degrees = "\u00B0C" # Degree symbol UTF-16
Degrees = "C"
HighCPUUsage = 90 # High CPU usage in %
HighCPUTemp = 65 # High CPU temperature in Celsius
CritCPUTemp = 80 # Critical CPU temperature in Celsius
HighMemUsage = 70 # High Memory utilization
HighDiskUsage = 60 # High Disk utilization
Uname = uname().nodename
phones = [["##########", "Consumer Cellular", True],["##########", "Sprint", True], ["#######", "##########", False]]
# runDef = [ Script Name, Delay in seconds, Send to stdout, Send email / sms ]
runDef = [["start", 30, False, True], ["check", 0, False, False], ["print", 0, True, False], ["flash", 0, True, True], ["mail", 0, False, True]]
Fuse = GPIO.input(4)
Power = GPIO.input(17)
if len(argv) > 0: # Should always be non-zero if called from CLI
envString = argv[0] # Contains the name by which the script was called
for runVal in runDef:
scriptName, scriptDelay, scriptPrint, scriptMail, *rest = runVal
if envString.find(scriptName) > 0: # Check if script called with this runVal value
sleep(scriptDelay)
break
else:
print("WTF?") # Not called from CLI
exit(1)
def pi_status(): # Main routine: always called by script
# Gather information about system
result1 = getTemperature()
result2 = getCPU()
result3 = getDiskUsage()
result4 = getMemUsage()
if scriptMail: # Called with Mail Send request: send email
if scriptName == "start":
sendText = "Raspberry Pi Startup notification\r\n"
else:
sendText = "Raspberry Pi Monitor Mail\r\n"
sendText = sendText + "Host Name: " + Uname + "\r\n"
sendText = sendText + result1+ "\r\n"
sendText = sendText + result2+ "\r\n"
sendText = sendText + result3+ "\r\n"
sendText = sendText + result4+ "\r"
sendMessage(sendText)
if scriptPrint: # Called with display request: send to stdout
print("Host Name: " + Uname)
print(result1)
print(result2)
print(result3)
print(result4)
def getTemperature():
cpuTemp = int(CPUTemperature().temperature)
Ctemp = "CPU Temperature: " + str(cpuTemp) + Degrees
if cpuTemp > CritCPUTemp:
sendText = "CRITICAL ALARM FROM HOST " + Uname + "!\r\nALERT: Critical temperature " + str(Ctemp) + ".\r\nShutting system down...\r"
sleep(10)
subprocess.run(["shutdown", "-h", "0"])
elif cpuTemp > HighCPUTemp:
sendText = "Alarm From Host " + Uname + "!\r\nWarning: High temperature " + str(Ctemp) + ".\r"
return Ctemp
def getCPU():
cpuPercent = int(psutil.cpu_percent(1))
Cusage = "CPU Usage: " + str(cpuPercent) + "%"
if cpuPercent > HighCPUUsage:
# Sending alert on high cpu usage."
sendText = "Alert From HOST " + Uname + "!\r\nWarning: High CPU Utilization " + str(cpuPercent) + "%\r"
return Cusage
def getDiskUsage():
for dp in psutil.disk_partitions():
diskUsagePercent = int(psutil.disk_usage(dp.mountpoint).percent)
diskPercent = "Disk Usage: " + str(diskUsagePercent) + "%"
if (diskUsagePercent > HighDiskUsage):
sendText = "Warning From Host " + Uname + "!\r\nWarning: High Disk Usage " + str(diskUsagePercent) + "%.\r"
return diskPercent
def getMemUsage():
memUsagePercent = int(psutil.virtual_memory().percent)
if (memUsagePercent > HighMemUsage):
sendText = "Alert From Host " + Uname + "!\r\nWarning: High Memory Usage " + str(memUsagePercent) + "%.\r"
sendMessage(alertMsg)
memUse = "Memory Usage: " +str(memUsagePercent) + "%"
return memUse
def getPower():
if not Fuse:
if not Power:
Text = "Main power failure.  Shutdown will occur shortly."
else:
Text = "Fuse failure."
SendMessage(Text)
pi_status()
lrhorer
#7
I was unfamiliar with node-red, so I looked it up.  It is just about the last thing on Earth I would want to use for this application.  I could, of course, use an external watchdog to keep track of the GPIO pins, but why add extra code if the code to handle the transition is already in FPP?  I could also take a brute force approach and spawn an external instance of `gpioinfo | grep GPIO4 | grep low`, but that is quite brittle and rather klunky.  An internal Python routine would be far more future proof and independent of the vagaries of gpioinfo.[
Edit: gpioinfo does not work as expected.  It only reports whether the pin is used and whether it is active low or high.  It does not report the actual pin state.
lrhorer
I have temporarily enabled GPIO4 to run the script both when the pin is rising and falling, and added an argument to tell whether the pin is high or low.  This works somewhat, but is far from ideal.
GPIO4 transitions low whenever power is no longer available to the string.  This implies one of two things.  Either the fuse feeding the string has blown, or main power has failed.  GPIO17 will also drop if the main power fails.  Ordinarily, I would be able to simply inspect both to see which is the case and respond appropriately in the script.  Using the value of the argument (argv[1]), I can discern the fact GPIO4 has transitioned low, but there is no way to do this outside of the instance when FPP makes the call.
To put it another way, Normally I should be able to run the script from the CLI using the alias `status_print`, which ideally should say:
Host Name: Lighting1
CPU Temperature: 49C
CPU Usage: 3%
Disk Usage: 23%
Memory Usage: 47%
Power OK.
Fuse Failure!
Case Temperature 44.9C
Battery Voltage 11.43 Volts
Fan On
Cooling Off
but the script is unable to make that determination except when it is called by FPP because of a failure.  Instead, all it can do is say:
CPU Usage: 3%
Disk Usage: 23%
Memory Usage: 47%
Power OK.
Fuse Status: Unknown
Fan On
Cooling Off
usmick78
Out of curiosity, will a Raspberry Pi 500 work with FPP?  I am a REAL newbie and am needing to know this.
Thank you in advance.
When in doubt, empty the magazine!
Better to be tried by 12 than carried by 6.
It should run it as the 500 has a RPi 5 at it's heart. FPP is designed to run headless so it might be a klunky experience having a "computer" that doesn't function as one. And the GPIO might be slightly "irregular" if you were to try using them although it appears to expose a 40 pin header. Try it and see what happens!
dirknerkle
The last version I used was 4.1 (or thereabouts). I spent a few hours getting used to the latest version which has, of course, multiple changes since 4.1, one of which is certainly the UI.
While the new UI is quite attractive, 4.1 was simpler to use for me. It had an "other" output option that allowed choosing the port (a GPIO port in my case) as well as the kind of data to send out that port. Simple, easy to understand, quick to configure. Imagine my surprise when the ability to do that no longer exists in the "other" output options.
To configure an equivalent function, I needed considerable help. It was suggested that I create a "string" under the PiHat tab using a virtual eeprom. HUH?  This is miles and miles and galaxies away from version 4.1.
I can understand the idea of a string, even though in my application, I had only four pixels. The application involves four patio lights. Granted, it's not an earth-shaking setup and I guess it's somewhat logical to think of it as a "string," just a very short one. But the idea of PiHat and eeprom never crossed my mind. I don't use a Pi Hat -- these four patio lights are driven directly from the GPIO port. And "eeprom?" Nope.  And to boot, it's not even a real eeprom, it's an invisible one!
Perhaps you might add the word Strings to the PiHat tab so that it reads PiHat/Strings so that a near brain-dead person like myself doesn't have to scour the manual (very nice, but not helpful in my case) and burn several hours looking around, trying to figure out how to replicate something in the new system that was brutally simple to do in an earlier version.
Thank you.
Santacarl
Hi All,
Can someone help me out?  This thread (FPP 8.4 released) would seem to indicate (as the latest release is usually posted here) it's the latest release yet up at the top of the page out beside "News:" it says that FPP 8.5.1 is the latest release.
Is 8.5.1 a beta or some test platform and us novices should, instead, stick with FPP 8.4?
breese
While there are some patches going into 8.5.1, if 8.4 is working for you, stick with it.
There is a lot of work being done for 9.X but that is Beta (but seems to be working on my pi 5).
If you have a spare SD card, you could always install 8.5 and do all the updates to make it current and see how it is for you.
Santacarl
Thanks for the response Breese.
I was doing a fresh install on a new Pi 4 so I don't know if 8.4 works for me or not!  Haha..  I just went to the 8.4 released thread a while back and downloaded 8.4.  When I got the new Pi 4 I simply installed the previously downloaded 8.4.  After installation I thought I'd check the website to see if a new release was pending while kicking myself for not checking before installation....DUH....  Anyhow, when I went to the site I saw that 8.5 note up top.
You mentioned using FPP version 9 on your Pi 5.  Is version 9 going to be backwards compatible or will it just work on the new 5 models?
