PixelController . com => F16v4 Pixel Controller (Blue) => Topic started by: James Odenbach on November 20, 2021, 11:41:54 AM
Title: F16V4 with TLS3001 issue
Post by: James Odenbach on November 20, 2021, 11:41:54 AM
Hello all, I have an F16V4 with build 13. It is setup with strings of 50 TLS3001 pixels. The issue is that it seems to be controlling each string as a single pixel. If anyone has any thoughts let me know. It had this issue with the original firmware and I just upgraded to the newest firmware (build 13) and the issue hasn't changed. I've attached the pixel config just in case.
Thanks all!
Title: Re: F16V4 with TLS3001 issue
Post by: tbone321 on November 20, 2021, 05:26:33 PM
The fact that the entire string type row is red indicates that it is not configured correctly and in this case, pretty much not at all.  Every port needs a string type, not just the first one.  After that, take a look at what you are sending from FPP and make sure that matches up.
