Total Members: 15497
Latest: packhawk
New This Month: 5
New This Week: 33
New Today: 5
Total Topics: 15590
Most Online Today: 98
Members: 5
Guests: 37
Total: 42
No signs of life, help
Started by projectortoph, September 23, 2022, 11:18:17 AM
projectortoph
Hi everyone,
I have a F48 v1.01 that runs my whole light show. It has been powered off since January until yesterday when I tried powering it on and got nothing, no OLED and no power LED. I verified my 5v power is working but still nothing. The F48 is mounted in a CG-1500 box on the wall of my garage year around but it is not powered. Any ideas for troubleshooting? Thank you.
Per manual "A 5V with a 3A minimum is required to power the controller. Use either the barrel connector OR the V2 Power Connector to power the board, NOT BOTH. This power supply only powers the controller, it does not provide any power to the pixels themselves. "
Assuming you have tried another outlet, and not something as simple as GCFI that has tripped.  You can make sure the power wires did not corrode from humidly or short out somewhere,  If your not getting any signs of life, sounds like the board could have went bad.
fauxton
Did you verify that the 5/12v switch or jumper is in place?  I'm not familiar with each version but I know most of them have it.
projectortoph
Thanks for the reply JonD. I have verified power and tried a brand-new Meanwell 5v 60A power supply. I'm only talking about the F48 board.
fauxton, the F48 controller only accepts 5v.
Quote from: projectortoph on September 23, 2022, 01:47:36 PMI have verified power and tried a brand-new Meanwell 5v 60A power supply.
The older smart receivers require 5.3 volts to run.  If you are using a meanwell power supply, you might crank up the volts to 5.3 and see if anything lights up.  If not turn it back down to 5.0.  If that was the issue, it would have probably showed itself last year though.
projectortoph
Thanks JonD, but the problem isn't with the receivers and the Meanwell power supply is outputing 5.3V.
I have emailed David Pitts and went through some basic troubleshooting but ultimately I will be sending it to him to look at.
The F48 manual stated 5v minimum, but it was for an older board revision.  You mentioned 5v, so if you were at 5.0, I thought there might a long shot that 5.3 might get you over the hump.  Some of the new smart receivers require 5.3 volts and was not sure if the newer F48 version did as well.  Glad your getting to the bottom of it.
Think I found a bug/corner case...please help by cooper5389
Today at 05:43:57 AM
Fpp 6.2 ui password by Mat-Moo
Today at 01:31:11 AM
Controller not keeping accurate time by jnealand
December 01, 2022, 09:38:16 PM
Raspberry PI 4 won't connect to WIFI by Poporacer
December 01, 2022, 07:28:48 PM
BRP Voting Plugin - Allow others to vote for your songs! by Barkers Random Projects
December 01, 2022, 07:20:53 PM
All pixels group ON effect by tkelba
December 01, 2022, 06:48:00 PM
FPP 6.2 Playlist/FPP Command/Run Script vs. Playlist/Script by richardln2
December 01, 2022, 06:16:19 PM
Help--Can't Get Sequence to Output by Oxytousc
December 01, 2022, 05:07:12 PM
Set Time/Date by breese
December 01, 2022, 04:07:57 PM
Differential Receiver Board Ports w/ F48 corrupted data by tkelba
December 01, 2022, 02:58:25 PM
