Total Members: 15484
Latest: MrCreed
New This Month: 106
New This Week: 20
New Today: 6
Total Topics: 15568
Most Online Today: 108
Members: 6
Guests: 60
Total: 66
F16V4 port 5 Lights flicker
Started by Martin Lamers, September 30, 2022, 01:45:49 PM
Martin Lamers
Port 5 lights flicker in test mode, changed strings, checked everything, no change?
Assuming you have two lights strings.  Both work if you test on port 4, and both flicker if you plug into Port 5?
Unplug the controller, pull the pigtail 4-pin phoenix connector from port 5 and swap with another one close by.  See if the problem follows the pigtail.  Sounds like the port 5 pigtail has a loose wire, or the pigtail itself is bad.  Do you have any expansions boards plugged into the F16V4?
Martin Lamers
Only the F16V4 board, using 4 ps. Moved the pigtails around and installed new pigtails the problem did not follow the pigtails.
The flicker was evident using the XLights test mode as well, however the flicker was not evident when outputting to lights with an XLights sequence.
Can't think of any reason from the controller side why port 5 would flicker and the other ports would work fine.  Have seen some weird expansion cable issues, but assuming the Falcon is configured for "Main Board Only" and no expansion cards installed that rules that out.
Usually when I see flickering, it is low power, or long/bad cable.  Could your brightness settings on the Falcon output ports be lower on port 5 than the rest?  I have never ran across the issue you are having... sorry.
rudybuddy
It might be worth checking voltage reading at board from PS....can't hurt.
Martin Lamers
The flickering seams to have gone away? after the fact I did add additional bonding between the four PS V- . we will see how it goes!
Thanks to all for help!
FPP Settings dropdowns not populating by jacksonho
Today at 03:20:26 PM
USB Wifi Adapter by jem5136
Today at 02:15:45 PM
FPP 6.x Matrix Issues by cmndr brain
Today at 01:41:55 PM
String ports question by Santacarl
Today at 12:42:38 PM
new piCaps in the works? by Bwinter
Today at 11:19:14 AM
Does FPP include an operating NTP server? by Aaron Maue
Today at 11:10:03 AM
Audio Stalls on 8th music sequence by clark
Today at 10:59:04 AM
Warning in Check Sequence about render caching by JonB256
Today at 09:09:47 AM
Uploading Models to FPP Remote by jnealand
Today at 07:46:08 AM
Audio issues by dkulp
Today at 07:29:34 AM
