Total Members: 15696
Latest: st3v3
New This Month: 14
Total Topics: 15827
Most Online Today: 65
Guests: 28
Total: 30
FPP Settings dropdowns not populating
Started by jacksonho, November 29, 2022, 07:01:50 AM
jacksonho
Hi all,
I am running into issues with some of the FPP settings drop downs not populating. Some are working but some are not, for example In can't see the below
Audio Output Device
Default Video Output Device
RTC
TimeZone
Apache logs seem to indicate an error, any idea how to solve this? It is throwing my config off because I can't select a time server for example
[Tue Nov 29 13:57:39.352548 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  file_get_contents(http://127.0.0.1/api/settings/AudioOutput/options): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized\r\n in /opt/fpp/www/common.php on line 428, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.373596 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  array_keys() expects parameter 1 to be array, null given in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.373749 2022] [php7:warn] [pid 1151] [client 192.168.0.19:54471] PHP Warning:  count(): Parameter must be an array or an object that implements Countable in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.415933 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  file_get_contents(http://127.0.0.1/api/settings/TimeZone/options): failed to open stream: HTTP request failed! HTTP/1.1 401 Unauthorized\r\n in /opt/fpp/www/common.php on line 428, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.416294 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  array_keys() expects parameter 1 to be array, null given in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
[Tue Nov 29 13:57:39.416377 2022] [php7:warn] [pid 1160] [client 192.168.0.19:54536] PHP Warning:  count(): Parameter must be an array or an object that implements Countable in /opt/fpp/www/common.php on line 430, referer: http://192.168.0.198/settings.php
jacksonho
No matter, I sorted it myself. I disabled the UI password and it worked.
What version of FPP.  This was fixed in 6.1.
jacksonho
Hi, I was originally on 6.0 but upgraded to 6.2 via the web interface. It was still an issue until I took away the UI password option. I re-enabled it just then and now it works fine. Perhaps it was a carry over issue from 6.0 and needed to be checked on and off to fix it?
Quote from: jacksonho on November 29, 2022, 03:20:26 PMI re-enabled it just then and now it works fine
Is there a specific reason you are even enabling the UI Password? That is typically not the preferred method. This does not provide you any type of security and is similar to putting a lock on your fridge in case someone breaks into your house.
Today at 09:37:23 AM
FPP Install on Raspberry Pi Zero W by JonB256
Today at 07:45:31 AM
March 20, 2023, 01:03:53 PM
March 19, 2023, 12:24:34 PM
Limitations on Video file size? by darylc
March 19, 2023, 02:53:52 AM
March 16, 2023, 05:25:46 PM
March 15, 2023, 01:17:55 PM
March 13, 2023, 09:29:28 AM
FM transmitters by Poporacer
March 12, 2023, 10:54:39 AM
fpp-videoCapture overwhelms F16v3 by k6ccc
March 10, 2023, 04:21:28 PM
