Total Members: 16845
Latest: onexbadxdodge
New This Month: 23
New This Week: 5
Total Topics: 16947
Most Online Today: 119
Guests: 61
Total: 61
Red status on E131
Started by TheMinionHouse, December 08, 2024, 07:08:07 PM
TheMinionHouse
On my controller the last few universes are showing red and those props are running, but glitching randomly.
The first 50 are good, the last 7 are red.
Using  FPP as my player.You cannot view this attachment.
#1
I don't have any F48v4 controllers, but think it is limited to 48 Ports.
TheMinionHouse
So, then, how can the Control support up to 72 4 Channel receivers?
I have 8 receiver chains.
1-4 A
5-8 A
9-12 A +B
13-16 A+B
17-20 A
21-24 A
25-28 A+B
29-32 A+B+C
In Local test mode everything seems to work fine, without glitching, and all the models are active when I add them.
It is when I play a sequence from FPP that the glitching starts.
It is only affecting, Ports 25-28 on B receiver, and 29-32 on C receiver.
Everything is a Mirror of each other, symmetrical display, other than the C channel Receiver that is running some side yard pixels.
So, if I can have 1024 pixels per Channel, is that per Channel Divided by the Receiver count?  So, with 3 receivers, I can only have 342 pixels per receiver?  Of does the A, B, C ect, Count as one of the 48 ports?
I am confused.
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMSo, if I can have 1024 pixels per Channel,
I assume that you mean port?
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMis that per Channel Divided by the Receiver count?
Not really
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMOf does the A, B, C ect, Count as one of the 48 ports?
Yes. 1A + 1B + 1C, etc. is the count for port 1. (But the 1024 per port is only in 32 port mode)
#4
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMEverything is a Mirror of each other, symmetrical display, other than the C channel Receiver that is running some side yard pixels.
I think that is what happens when you go over 48 ports.  Probably mirroring ports 45-48 per board configuration settings picture.  Even the F16v4... if you install two expansion boards (16+16+16=48), and try to use the on-board receiver or DMX ports, the ports mirror some of expansion board ports.  Your test is not working, it just happens to be mirroring other ports running the same test patterns.
The F48v4 supports 12 chains.  (1 normal mode SR or up to 6 Smart Mode A-F SR per chain)  You will be limited to 704 pixels (680 average) per port in 48 port mode.
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMSo, then, how can the Control support up to 72 4 Channel receivers?
Because you can put up to 6 receivers on each RJ45 port (A-B-C-D-E-F) That is if you use the V4 SRx1 Blue.
Quote from: JonD on December 09, 2024, 01:55:54 AMI think that is what happens when you go over 48 ports.
How can you go over 48 ports? There are only 12 RJ45 connections and each connection is for 4 ports
Quote from: JonD on December 09, 2024, 01:55:54 AMProbably mirroring ports 45-48 per board configuration settings picture.
The mirroring that this refers to is the 4 On-Board Pixel ports. Those 4 ports will mirror one of the RJ45 ports depending on your board configuration.
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMI have 8 receiver chains.
And you have almost 10,000 pixels using just 12 ports? (this is a clue)
Quote from: TheMinionHouse on December 08, 2024, 10:32:27 PMIt is when I play a sequence from FPP that the glitching starts.
This is probably due to a configuration problem. We could use several screenshots (please post screenshots from your computer, it shows more detail)
1. xLights Controller page
2. xLights Layout page
3. xLights Visualizer page
4. F48 E1.31 page
5. F48 Pixel Output page.
6. FPP Outputs Page with E1.31 tab open
You could jump in the Zoom Room if you want a better explanation and a walk through on how to properly configure your controller. I think you are missing a few concepts.
If you don't know what the Zoom Room is or how it works, this might help
TheMinionHouse
I will get the screen shots tonight.
Quote from: Poporacer on December 09, 2024, 08:18:39 AM
QuoteI think that is what happens when you go over 48 ports.
QuoteProbably mirroring ports 45-48 per board configuration settings picture.
There is a DMX port in addition to the 12 RJ-45s, but I was referring to OP showing ports 49-57 listed in red and suggesting they could test these ports and were working fine.
Quote from: JonD on December 09, 2024, 10:28:17 AMbut I was referring to OP showing ports 49-57 listed in red
The OP wasn't showing ports that were listed in red, those were universes being received listed in red, and I am pretty sure I know why and that is why I asked for screenshots.
I think that is what is throwing things off, he posted Universes but talking about ports and there is NO direct correlation between the two and I am 99% certain his misunderstanding of how things work has lead to some major mis-configurations.
TheMinionHouse
Here are my screen shots.
I am using the top 4 ports and the bottom 4 ports in the controller.
Maybe I did misconfigure it, but I am so frustrated I can't see the LED for the pixel at this point.
TheMinionHouse
I did find this...
Up to 48 universes will be shown in a single column, and up to 4 columns may be shown.  The different columns for each group of 48 universes will have different background colors, as shown in Figure 4-29.  This is for visual clarity only, and does not have any effect on the controller operation.
They could have picked a different color...   :o
Still having the glitching though.
Quote from: TheMinionHouse on December 09, 2024, 05:45:04 PMThey could have picked a different color...
LOL
Well, something looks a little odd. You posted 2 screenshots of your pixel outputs page from the controller and they are different? On one, you have models assigned to Ports 1-32 and the other 1-16.
Which one are you using?
Which receivers are you using?
Ports 29-32 look a little strange with nothing on receiver A
TheMinionHouse
Yea, I am using 17 through 32, I guess I had old screen shots in the folder from Last year.  Opps.
Sorry for that confusion.
I am using the Blue Smart ones, circa 2022.
Yes, 29-32 "A" is deployed and I have things plugged into it, just have not gotten around to assigning the models in Xlights.  It is Pixel modules inside my inflatables, not critical to my show.   They will get assigned this week.
Quote from: TheMinionHouse on December 10, 2024, 07:17:27 AMYea, I am using 17 through 32,
Can we see this configuration?
If you press the test button on the remotes, how do the lights behave?
You might have a bad cable
TheMinionHouse
I will snap shot the changes tonight and upload a video.
January 14, 2025, 05:54:32 PM
January 14, 2025, 11:55:25 AM
January 14, 2025, 07:42:55 AM
January 12, 2025, 10:40:05 AM
FPP 8.4 released! by dkulp
January 12, 2025, 08:20:06 AM
xLights.org forum registration waiting for approval for several months. by darylc
January 11, 2025, 12:42:54 AM
FPP sequence fade by CaptainMurdoch
January 10, 2025, 08:19:33 AM
Combining multiple shows (models, sequences, etc.) into a single xLights show by JonD
January 09, 2025, 07:41:31 PM
F8 Distro Board and 36V power supplyu by JonD
January 09, 2025, 12:04:31 PM
FPP-channel & universe numbers? by JonD
January 09, 2025, 07:00:58 AM
