Total Members: 16427
Latest: digilabpg
New This Month: 21
Total Topics: 16406
Most Online Today: 126
Guests: 62
Total: 62
difficulty with SRx2
Started by jkp, October 12, 2023, 11:17:14 AM
jkp
I have a F48V4 (build 27). I am only able to get the first 4 pixel outlets to work on the SRx2. Currently ID selection is set to 0 and the SRx2 is connected to 1st port of the F48V4 and Pixel Outputs display as 1a, 2a, 3a, 4a, 5a, 6a, 7a, 8a. I have gone through every ID selection and the best I am able to do is duplicate 1a on 5a, etc. but can't get 5a-8a to function on their own. I am also confused on the outputs numbers. I was expecting to see 1a-4a and 1b-4b. I am missing something but not sure what it is. Hopefully someone can point me in the right direction.
I am able to daisychain a second smart receiver to the SRx2and it works fine.
Note: I have gone through all the posts related to SRX2 but none helped me resolve the issue.
Quote from: jkp on October 12, 2023, 11:17:14 AMPixel Outputs display as 1a, 2a, 3a, 4a, 5a, 6a, 7a, 8a.
I don't think you  understand how the smart receivers work?
Quote from: jkp on October 12, 2023, 11:17:14 AMthe SRx2 is connected to 1st port of the F48V4
What Port number does that indicate on the board 1-4 correct? Then that means that every port connected to that cable will be some variant of 1-4. So for example, if you only have the one SRx2 then the 4 ports connected to the ID section will be A variants (1A, 2A, 3A, 4A) the ID+1 will be B variants (A+1=B) so those 4 ports will be 1B, 2B, 3B, 4B.
Quote from: jkp on October 12, 2023, 11:17:14 AMbut can't get 5a-8a to function on their own
Those would be on receivers plugged into the 2nd port on the F48.
jkp
You are right... I do not understand it... thanks for pointing out the obvious.
the question remains.... how do I get the 2 set of 4 ports to work on the SRx2? plug a cable between port 2 of the F48 and to the data port of the SRx2?
I simply want to connect the SRx2 to my F48 and have all 8 ports work.
Quote from: jkp on October 12, 2023, 01:18:49 PMhow do I get the 2 set of 4 ports to work on the SRx2?
Define the models in the visualizer to be on the correct ports, Like I said, the props on the "ID" ports will 1A, 2A, 3A, and 4A, and the "ID +1" will be 1B, 2B, 3B, and 4C.
Jump in the Zoom Room and it can probably be explained a little easier for you to see.
bloojoop
Also, the rotary dial on the srx2 needs to be set to A... Then the first 4 ports will be your 1-4A ports and your 2nd 4 ports will be your 1-4B ports.
--Ron A.
configuration by Poporacer
Today at 07:34:10 AM
April 23, 2024, 03:48:12 PM
F32v5 Release Date by JonD
April 23, 2024, 09:14:57 AM
April 22, 2024, 01:30:45 PM
April 18, 2024, 03:20:31 PM
April 15, 2024, 03:40:34 PM
April 14, 2024, 06:21:46 PM
April 14, 2024, 12:00:50 PM
Born in the USA by Xmas!
April 13, 2024, 03:25:16 PM
April 12, 2024, 08:53:19 PM
