Total Members: 16427
Latest: digilabpg
New This Month: 21
Total Topics: 16406
Most Online Today: 126
Guests: 72
Total: 73
F16V3 with smart recievers
Started by Sjcoan, November 08, 2023, 05:54:03 AM
Sjcoan
Using 1 and 2 on the dial instead of A and B did the trick. Thank you JonD and K-State for all of your help.
Now If I can figure out why I have a few pixel strings that don't want to display the right color I'll be all set, any reason why they would be green instead of blue?
When I run a sequence directly from Vixen they are fine, but when I run the same sequence through the FPP there are about three strings that are green instead of blue. There are six strands per port and the others are working as they should.
Channel count is off somewhere causing the colors to be out of order, or maybe you are using RBG strings and configured for RGB.  Assuming since it is working out of vixen that the falcon controller test works as well?
Maybe a print screen of your Falcon output settings\pixel page and FPP Channel outputs?
Sjcoan
I had a start channel number switched, all set, thank you again!
configuration by morrydavis
April 23, 2024, 04:34:20 PM
April 23, 2024, 03:48:12 PM
F32v5 Release Date by JonD
April 23, 2024, 09:14:57 AM
April 22, 2024, 01:30:45 PM
April 18, 2024, 03:20:31 PM
April 15, 2024, 03:40:34 PM
April 14, 2024, 06:21:46 PM
April 14, 2024, 12:00:50 PM
Born in the USA by Xmas!
April 13, 2024, 03:25:16 PM
April 12, 2024, 08:53:19 PM
