Total Members: 16420
Latest: donw377
New This Month: 13
New This Week: 7
Total Topics: 16396
Most Online Today: 159
Guests: 81
Total: 81
FPP After Hours Music Plugin has been updated
Started by jcross, February 15, 2024, 11:44:03 PM
jcross
I have just released the updated version of fpp-after-hours that now installs on FPP v8 and is backwards compatible from FPP v7.0 up.
I am hoping anyone who uses it on v7 or is testing v8 can give it a whirl and let me know if any bugs show up for them.
Improvements are:
-Completely redesigned UI that is responsive and edits are live (in most cases)
-Updated prerequisite installer that shows real time status of the install progress (same method that fpp update uses)
-All data and control is now handled by the fpp-after-hours API
-Updated help pages that parse out the readme.md file and display it live with images and table of contents links (available offline)
**the readme.md file is still being worked on and will be completed in the next few days (currently missing API endpoint details)
-change to how streams are tested for connectivity
-updated all scripts to work properly with php 8 (and remain backwards compatible)
For quick reference here are two stream I have been testing with:
Radio X-Mas                http://77.75.16.229:443
Halloween Hit Radio     https://halloween-hit-radio.stream.laut.fm/halloween-hit-radio
Thanks,
Jason
breese
I have it running on FPP 7.5 and v8.
Basic install and run seems to be functioning as expected so far.
2 notes:
1: Volume cannot be set before starting stream and resets to 100% after stopping and starting.
2: (Request) Would be nice to have some type of indicator on the home screen to show it is running.
I use and am testing with
Miller Home Stream
https://radio.themillerlights.com/listen/themillerlights/radio.mp3
One thing to consider is to change it to use FPP Commands. It is a simple process and makes it so much easier to use!
jcross
#3
Quote from: breese on February 16, 2024, 04:31:29 AMI have it running on FPP 7.5 and v8.
2 notes:
Miller Home Stream
Volume can be set once known on each individual stream row and it will use that volume on start (or are you talking the system volume?)
Is there a hook available to push plugin details to the main screen?
jcross
Quote from: Poporacer on February 16, 2024, 06:14:56 AMOne thing to consider is to change it to use FPP Commands. It is a simple process and makes it so much easier to use!
Interesting, I didn't realize we could plug into those... I will make this change for sure!
jcross
Quote from: jcross on February 16, 2024, 08:34:20 AM
FPP Commands code has been added and documentation completed.  Thanks for that suggestion, it is much easier for the end user!
Quote from: jcross on February 16, 2024, 01:31:22 PMFPP Commands code has been added and documentation completed
Awesome!
Quote from: jcross on February 16, 2024, 01:31:22 PMThanks for that suggestion, it is much easier for the end user!
I thought you might like it!
breese
When After Hours is not running, it logs this every minute.
2024-02-21T04:49:01.948804-06:00 FPP8 CRON[14562]: (fpp) CMD (/usr/bin/php /home/fpp/media/plugins/fpp-after-hours/cronMonitorStream.php >/dev/null 2>&1)
