Total Members: 15532
Latest: travispauley
New This Month: 40
New This Week: 28
New Today: 6
Total Topics: 15647
Most Online Today: 74
Members: 4
Guests: 63
Total: 67
F16 v2 red
Started by wharrell, December 05, 2021, 02:27:17 PM
wharrell
I have a f16 v2 r and output#7 hase stopped working all the other ones are fine any help
Did you check the fuse?
wharrell
Yes the fuse is good it just stopped working
I recently had to replace 5 fuses on one of F16v2rs which is why I asked.  Have swapped strings between port 7 and something else.  Just use test mode to check.
wharrell
I did a test mode and swapped strings still nothing I'll try power injection and see
JonB256
Output #7 shares an "output" chip with channels 5,6 and 8. Usually, if that chip goes bad, all 4 outputs stop. It's possible that just #7 died. On the F16v2 Red (I have one), those are socketed chips. There are four of them across the board. If you really, really want to check, swap chips carefully. If the problem moves, then you need a new chip. If it stays at #7, then look on the bottom of the board for bad solder.
pixelpuppy
QuoteOutput #7 shares an "output" chip with channels 5,6 and 8. Usually, if that chip goes bad, all 4 outputs stop. It's possible that just #7 died.
I have had just one output go bad when I accidentally shorted the data line for one output.  The other outputs on the quad driver chip still worked fine.   This was verified, as you said, by swapping chips with another bank.   Easy to test and easy to fix with a new chip in the socket.
wharrell
Thanks I will give that a try
wharrell
ok so I checked power im good there, I swapped the chip with another still nothing no data
