Total Members: 16897
Latest: 1492
New This Month: 13
Total Topics: 16988
Most Online Today: 68
Members: 4
Guests: 28
Total: 32
Overlay Matrix: write more than one pixel at a time ?
Started by zaicik, August 06, 2024, 12:44:57 PM
zaicik
Looking to make "generative" scripts, I want to feed "live" data to FPP (e.g. sensor-based)
While the API will gladly give an overlay model's full contents (e.g. /api/overlays/model/:ModelName/data)  I haven't found how to feed it data other than one pixel at a time (/api/overlays/model/:ModelName/data)
While this API is practical to draw one pixel at a time from the matrix tool menu, I'm guessing there might be a more efficient route if I want to take more control...
Any tips / suggestions ? 🙏
There is no API command to achieve that today.  We would welcome a pull request for an implementation of one.
You could draw inspiration from the CopyFileToMappedBlock function in https://github.com/FalconChristmas/fpp/blob/master/src/fppmm.cpp
If the scripts are running on the same FPP instance as the models, the best bet is to mmap the data blocks from /dev/shm .   Each of the models gets a file in there of the data and you should be able to write into it directly.
zaicik
Thanks for the pointers.
I'm gonna start by fiddling with /dev/shm as per @dkulp 's recommendation, and see where it takes me.
The data blocks being accessible this way looks like an amazing opportunity by the way: on a powerful enough Pi or BB, one could probably run Processing scripts and output each frame to a matrix. The syntax is extremely simple and could be a huge level up with minimal coding abilities.
Regarding:
Quote from: darylc on August 07, 2024, 06:02:53 AMThere is no API command to achieve that today.  We would welcome a pull request for an implementation of one.
Contributing to the API is likely above my current coding abilities but let's see how much I learn along the way and I'll try my best.
niemy
Hello
@zaicik did you manage with sending data ? I try also send let say native data to the falcon and I don't know how to start ?
Generally I need send a data for scoreboard but from time to tim I would like display some GIF etc.
Also I thought about DDP protocol but I don't know if it's efficient enought.
PixelOverlay-Clock - Revisited Again by datajack
Today at 04:48:12 AM
Today at 04:38:32 AM
March 16, 2025, 11:58:28 AM
March 16, 2025, 05:07:48 AM
K16A-B Issue by nolatron
March 15, 2025, 01:52:26 PM
F16V5 and SRx1 v5 by jkp
March 15, 2025, 07:19:44 AM
Differential Board: PSU & Enclosure by hakko808
March 14, 2025, 09:17:01 AM
FPP 8.4 Back up by Jradical
March 13, 2025, 05:38:18 AM
FPP on Pi5 won't start with "FPPD boot delay" set to 2 min or higher by dnapier65
March 12, 2025, 05:39:00 PM
OBJ File in Sketchup by dspenman
March 11, 2025, 09:19:08 AM
