Total Members: 17219
Latest: Ash
New This Month: 18
Total Topics: 17305
Most Online Today: 250
Guests: 182
Total: 182
Bad data on daisy chained SRX1-PSU
Started by davidr236, December 03, 2025, 01:26:28 PM
davidr236
Hey guys, long time lurker here and have mostly been able to figure out all my issues with search. Coming to a dead end now and seeing if anyone can help me out.
My Setup:
I am running a Falcon F16v3 with 2 daisy chained SRx1-PSU off of the top RJ45 connector on the board. I also have a Holiday Coro Alpha Pix 16 connected to the ETH1 port. All of these are running off a Pi3b with FPP over wireless.
The SRx1's are using 1 and 2 on the dial, and the dip switches are correctly set for their position in the chain.
Issue: Port 1, (17a and 17b, both controllers) are very glitchy in the first handful of nodes. Operational, but colors are off and its just flashes weird. Port 2 (18a and 18b) are completely non operational. Just gives the shimmer effect to all props plugged into the second port on both controllers.
Under test mode via the controller button all nodes function as they should on all ports.
Things I have tested:
-Multiple network cables. Testing passed on cable tester.
-pigtail attachments
-Using A-B on the dial and not 1-2
-Switching out SRX1-PSU's
-All firmware is up to date on the f16 and FPP
It seems like I am maybe getting some sort of bad data signal since all the nodes operate fine under manual testing. Maybe my DMX port is bad? I can get a new Falcon but would hate to throw money at something that won't fix the problem.
Any ideas? Thanks for the help!
davidr236
Well I got Port 1 back via a factory reset of the F16v3. Port 2 is still flashing on both remotes though. Seems like there is a problem with the #2 Serial Port. I have them all set to pixel data on the web interface. Looking into maybe problems with the FPP?
allknowing2012
cable or cable glands. The cable has a pair for each port - so a pair is bad or a pin in gland is bad.
davidr236
That's what I thought as well. Tested all cables and glands with a tester and everything was a pass. Even made a new cable
davidr236
For anyone looking in the future. After troubleshooting every possible thing, I acquired an expansion board and everything works perfectly now. Looks like the serial port on the f16v3 is bad.
FPP MIDI plugin installed but wont trigger Playlist by MikeKrebs
January 20, 2026, 08:48:20 PM
FPP 9.5-1 causing 192-168-8-1 for most WiFi IP by Sawdust
January 20, 2026, 01:52:27 PM
pocketbeagle2 - OLA with PRU DMX output by s-light
January 20, 2026, 01:22:17 AM
Long term issue with FPP on Beagle by Sawdust
January 18, 2026, 11:50:52 PM
FPP driving P10 and also pixel outputs - several options by k6ccc
January 18, 2026, 05:49:34 PM
LoRa plugin. Is it worth pursuing in 2026 by dkulp
January 18, 2026, 05:18:50 PM
SRx4 Long Range Quad SmartReceiver by tbone321
January 13, 2026, 03:32:30 PM
Pixel Port by LedMutt
January 13, 2026, 12:57:46 AM
Peace Stake material by LedMutt
January 12, 2026, 12:15:36 AM
Forbidden Error Port 80 by darylc
January 11, 2026, 10:24:48 PM
