Total Members: 17237
Latest: Routhhurwitz
New This Month: 1
Total Topics: 17328
Most Online Today: 303
Most Online Ever: 8375
(February 21, 2026, 03:58:04 AM)
Guests: 214
Total: 214
Issues with firmware update
Started by 2Couyon, January 31, 2026, 09:10:24 AM
2Couyon
Trying to update my F16v3 to fw v2.59. I've tried different microSD, but still won't do anything during the bootloader install. I've pushed the SD Card all the way down, as well as backed it off a little. Nothing works.  :'(
Downloaded F16V3_2_59.zip & placed F16V3_BootloaderUpdater_v1.00.fal on a FAT32 formatted microSD. (16GB & 8GB)
Any tips/tricks?
-Couyon's Holiday Lights
..................... Intermediate Level. Since 2019. Equipment RPi 4B w/FPP; Falcon F16v3; running on xLights
Todd
Mine was a pain in the *** when I did it before Christmas. I put the boot loader on one so card 32gb or less sd card. And the firmware on another. 32gb or less. It won't work with a larger sd card. Be sure to  follow the instructions on pixel controller.com exactly. Mine took multiple try's to get it to go. The same issue was on my F48. But it eventually went and all was good.
Todd L.
Kimberly, WI
Falcon F16V3,F48, Kulp 32A-B, FPP, X-Lights, LOR, Pi 3B
Quote from: 2Couyon on January 31, 2026, 09:10:24 AMDownloaded F16V3_2_59.zip & placed F16V3_BootloaderUpdater_v1.00.fal on a FAT32 formatted microSD. (16GB & 8GB)
That is the wrong file if you are already running 2.56 (per your other thread).  You need the .fl2 file
2Couyon
Quote from: Todd on January 31, 2026, 02:18:54 PMMine was a pain in the *** when I did it before Christmas. I put the boot loader on one so card 32gb or less sd card. And the firmware on another. 32gb or less. It won't work with a larger sd card. Be sure to  follow the instructions on pixel controller.com exactly. Mine took multiple try's to get it to go. The same issue was on my F48. But it eventually went and all was good.
Yeah I am following it exactly. Tried a 8GB & 16GB SD card. It is like I don't even put a card in there.
2Couyon
Quote from: darylc on January 31, 2026, 02:24:43 PM
The instructions say to do the *.FAL file first.
  • Replacing bootloader. (These steps are only done once)
    1) Place BootloaderUpdater_v1.00.fal on a MicroSD card (32GB or Smaller, formatted Fat32).
    2) Place MicroSD card into controller and apply power.
    3) The application will be loaded and the screen will prompt to remove sd card and power down then up.
    4) Remove SD card.
    5) Power Down/up
    6) The application will replace bootloader.
2Couyon
Quote from: 2Couyon on February 02, 2026, 04:36:13 AM
    4) Remove SD card.
    5) Power Down/up
Are you saying that since I am at 2.56, I do not need to run the Bootloader and I can go directly to Upgrading the Firmware?
  • Updating Firmware (These steps taken for each firmware update)
    1) Place .fl2 file MicroSd card
    2) Power Down/Up
    3) The firmware will install
    4) Remove card when finished and power down/up.
    5) Controller will boot
allknowing2012
Correct - it is not super clear but that is only needed if you are coming from 2.0x versions.
Since you are having issues .. I would do the factory reset as well.
2) Power Down
3) Hold in select button (Next to right button).
4) Power up while holding button. The controller should display message stating a reset is occurring.
Then ...
2) Power Down/Up
Todd
Quote from: 2Couyon on February 02, 2026, 04:34:26 AM
Are you holding the select button down while powering back up with the bootloader as card inserted?
Todd L.
Kimberly, WI
Todd
Todd L.
Kimberly, WI
2Couyon
Quote from: Todd on February 03, 2026, 04:48:20 PM
So you have to "hold the select button down" to install the Bootloader as well?
Quote from: 2Couyon on February 05, 2026, 10:06:47 AMSo you have to "hold the select button down" to install the Bootloader as well?
You don't need the bootloader, it's already been done since you are on 2.56
Just do this bit:
2) Power Down/Up
2Couyon
Quote from: darylc on February 05, 2026, 09:20:05 PM
Just do this bit:
2) Power Down/Up
Yeah... Just needed to do this step.
Thanks for all the assistance.
Can you update 3b+ to 9.5.3? by SCUBA
April 12, 2026, 01:50:41 PM
Moving Head Color by SCUBA
April 12, 2026, 11:00:42 AM
FPP 9.5 on Linux by coyoteray
April 11, 2026, 05:49:56 PM
VSA to FPP conversion program by Scaregroundspdx
April 02, 2026, 01:42:54 PM
Limitations of Matrix Display by conceptpl
March 27, 2026, 03:22:53 AM
F16V4 IP Address by MikeKrebs
March 23, 2026, 08:21:32 PM
Help troubleshooting by aaronhess
March 19, 2026, 09:21:24 AM
Can't seem to get my network connections right. by Poporacer
March 16, 2026, 11:21:39 AM
F16v3 Expansion bad resistors by 2Couyon
March 13, 2026, 04:03:59 PM
HUB75 P4 1/10 Matrix by k6ccc
March 13, 2026, 08:45:44 AM
