Total Members: 17237
Latest: Routhhurwitz
New This Month: 1
Total Topics: 17328
Most Online Today: 303
Most Online Ever: 8375
(February 21, 2026, 03:58:04 AM)
Guests: 260
Total: 261
P2.4 128X64 32S (ICND2153/TC7262)
Started by timl, February 22, 2026, 01:45:02 PM
timl
I have a case of these LED Panels at a great price.
I have tried searching for software that supports these chip sets.
LED Vision has the Driver but not the Decoder.
I now have the panel connected to ColorLight 5A-75E Receiver and a Pi-4 running FPP V9.5.
The display is scrambled and to me it's the Decoder issue.
Is there a way to set the Driver/Decoder chip sets for FPP?
Attached is an image of the display.
The colors change and all that.
You need to supply a lot more information than this.  How did you define the panel in the color light card?  How did you define the matrix or a single panel in FPP?  What is the model and panel type of these panels?  Just saying you have a LED panel hooked up to a color light card means very little.  That's like saying I need spark plugs for my car and giving no further information than that.
QuoteIs there a way to set the Driver/Decoder chip sets for FPP?
I am really a noob noobier noobest with panels but I thought that was the task for the colorlight.
@timl You have to get a perfect image from your computer on ledvision before you try to do anything with FPP.
timl
I found that these driver chips require the PWM firmware on the ColorLight 5A-75A card.
Version 9.80 currently.
I am now able to get the image I expected on the panel.
I'm still trying to work out why I get a little flicker every now and again.
The drivers are ICND2153 and the Decoders are TC7262 (Set to 138 Decoder seems to work).
I used LED Upgrade to install PWM-9.80 to get the display to display anything at all.
I setup "Screen Size and Count Settings" to 128X64.
On the "Receiver Parameter" page it shows the module size of 128W×32H, not sure why and would like to know.
When I do "Intelligent Settings" all screens work as expected until I get to Routing and there is only 32 Rows, somewhere I heard that is normal (YouTube?).
The display when showing the default display occasionally flickers.
I have tried several DCLK settings and the fastest that works seems like 15.6Mhz and down to 5.0Mhz still works.
Same with GCLK but I still get the same image with a setting up to 25.0Mhz
I have tried from 0-500 for blanking and it seems to have no effects. Larger values seem to dim the screen.
Receiver Mapping is also set for 128X64
Anther issue I have is when I add a second module both screens display the same thing.
I remember in some video that was talked about it but I can't find where.
The next step is FPP.
Quote from: timl on February 24, 2026, 03:37:13 PMAnther issue I have is when I add a second module both screens display the same thing.
You need to fix that before moving onto FPP
Can you update 3b+ to 9.5.3? by SCUBA
April 12, 2026, 01:50:41 PM
Moving Head Color by SCUBA
April 12, 2026, 11:00:42 AM
FPP 9.5 on Linux by coyoteray
April 11, 2026, 05:49:56 PM
VSA to FPP conversion program by Scaregroundspdx
April 02, 2026, 01:42:54 PM
Limitations of Matrix Display by conceptpl
March 27, 2026, 03:22:53 AM
F16V4 IP Address by MikeKrebs
March 23, 2026, 08:21:32 PM
Help troubleshooting by aaronhess
March 19, 2026, 09:21:24 AM
Can't seem to get my network connections right. by Poporacer
March 16, 2026, 11:21:39 AM
F16v3 Expansion bad resistors by 2Couyon
March 13, 2026, 04:03:59 PM
HUB75 P4 1/10 Matrix by k6ccc
March 13, 2026, 08:45:44 AM
