Total Members: 16931
Latest: encore
New This Month: 7
Total Topics: 17017
Most Online Today: 100
Guests: 88
Total: 88
Disabling the 'built-in' e131 server?
Started by sirwesley, December 09, 2020, 09:32:54 AM
sirwesley
Trying to run my own custom e1.31 server on the FPP.  Is there anyway I can disable the built-in e1.31 server to free up the 5568 port so my custom NODEJS App will run.
I posted over in the FFP Discussion board, but that was before I saw this more technical board.
https://falconchristmas.com/forum/index.php/topic,13757.0.html
When starting up the app, I'm getting:
Error: bind EADDRINUSE 0.0.0.0:5568
You would need to comment out a line of code in the source and recompile to do this. Even when not running in bridge mode, fppd listens on the E1.31 port so that it can log warnings if it is being sent E1.31.
If you want to give it a try, edit /opt/fpp/src/fppd.c and search for 'Fake_Bridge_Initialize' and comment out that line of code.  cd to /opt/fpp/src/ and run "sudo make fppd && systemctl restart fppd' and when fppd restarts it shouldn't be listening if you are not running in Bridge mode.
sirwesley
Just found it prior to your reply.
AddFakeListener(E131_DEST_PORT, "E1.31", callbacks);
Thanks for your feedback.  I'll give it a shot and report back.
sirwesley
Okay, I was able to recompile and get my server running now along side my Node App.  Much thanks for that!
However, now even though I have my controller setup to use e1.31 unicast to 127.0.0.1 (and also tried multicast), for some reason the FPP isn't sending to it / Looping it back to 127.0.0.1.
  • I'm able to send FPP e131 data and receive it on Xlights PC.
  • I'm able to send Xlights e131 data and receive it on FPP.
  • Just can't get the data looped back (internally) to the 127.0.0.1 address, it would appear.
Any suggestions on configuration for the routing table or whatever so that my local app and FPP can talk?
I don't recall if there is anything specific preventing 127.0.0.1 loopback, but you could also try the eth0 IP and see if that works.  I thought we recently looked into a case where the user was looping back unintentionally but can't remember the specifics.
sirwesley
Unfortunately, specifically targeting the IP of either eth0 or wlan0 didn't work.  As you can see below in my netstat query, my 6658 port is only listening on 0.0.0.0 and not localhost as is ntp.
Not sure what I need to do to configure it so that I get localhost added.  Ideas?  Route add <cmd>?
fpp@FPP:~ $ netstat --listen
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address          Foreign Address        State
tcp        0      0 0.0.0.0:domain          0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:ssh            0.0.0.0:*              LISTEN
tcp        0      0 localhost:smtp          0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:microsoft-ds    0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:32322          0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:4200            0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:rsync          0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:netbios-ssn    0.0.0.0:*              LISTEN
tcp        0      0 0.0.0.0:http            0.0.0.0:*              LISTEN
tcp6      0      0 [::]:domain            [::]:*                  LISTEN
tcp6      0      0 [::]:ftp                [::]:*                  LISTEN
tcp6      0      0 [::]:ssh                [::]:*                  LISTEN
tcp6      0      0 [::]:microsoft-ds      [::]:*                  LISTEN
tcp6      0      0 [::]:rsync              [::]:*                  LISTEN
tcp6      0      0 [::]:netbios-ssn        [::]:*                  LISTEN
udp        0      0 0.0.0.0:57263          0.0.0.0:*
udp        0      0 0.0.0.0:5568            0.0.0.0:*
udp        0      0 0.0.0.0:37919          0.0.0.0:*
udp        0      0 0.0.0.0:domain          0.0.0.0:*
udp        0      0 0.0.0.0:32320          0.0.0.0:*
udp        0      0 0.0.0.0:bootps          0.0.0.0:*
udp        0      0 FPP:ntp                0.0.0.0:*
udp        0      0 192.168.1.44:ntp        0.0.0.0:*
udp        0      0 localhost:ntp          0.0.0.0:*
udp        0      0 0.0.0.0:ntp            0.0.0.0:*
udp        0      0 192.168.1.25:netbios-ns 0.0.0.0:*
udp        0      0 192.168.1.44:netbios-ns 0.0.0.0:*
udp        0      0 FPP:netbios-ns          0.0.0.0:*
udp        0      0 192.168.7.25:netbios-ns 0.0.0.0:*
udp        0      0 192.168.7.2:netbios-ns  0.0.0.0:*
udp        0      0 0.0.0.0:netbios-ns      0.0.0.0:*
udp        0      0 192.168.1.2:netbios-dgm 0.0.0.0:*
udp        0      0 192.168.1.4:netbios-dgm 0.0.0.0:*
udp        0      0 FPP:netbios-dgm        0.0.0.0:*
udp        0      0 192.168.7.2:netbios-dgm 0.0.0.0:*
udp        0      0 0.0.0.0:netbios-dgm    0.0.0.0:*
udp        0      0 0.0.0.0:46225          0.0.0.0:*
udp        0      0 0.0.0.0:45719          0.0.0.0:*
udp        0      0 0.0.0.0:mdns            0.0.0.0:*
udp6      0      0 [::]:domain            [::]:*
udp6      0      0 fe80::ba27:ebff:fe6:ntp [::]:*
udp6      0      0 fe80::ba27:ebff:fe3:ntp [::]:*
udp6      0      0 localhost:ntp          [::]:*
udp6      0      0 [::]:ntp                [::]:*
udp6      0      0 [::]:mdns              [::]:*
udp6      0      0 [::]:48422              [::]:*
fpp@FPP:~ $ route -n
Kernel IP routing table
Destination    Gateway        Genmask        Flags Metric Ref    Use Iface
0.0.0.0        192.168.1.1    0.0.0.0        UG    0      0        0 wlan0
192.168.1.0    0.0.0.0        255.255.255.0  U    0      0        0 eth0
192.168.1.0    0.0.0.0        255.255.255.0  U    0      0        0 wlan0
192.168.1.1    0.0.0.0        255.255.255.255 UH    0      0        0 wlan0
192.168.1.1    0.0.0.0        255.255.255.255 UH    0      0        0 eth0
192.168.7.0    0.0.0.0        255.255.255.0  U    0      0        0 usb0
I'm pretty sure the UDPOutput code will specifically block sending any data to itself.   If I try to configure 127.0.0.1, I see:
2020-12-10 16:32:20.682 (19945) channeloutput/UDPOutput.cpp:309: UDP Output set to send data to myself.  Disabling - 127.0.0.1
Surprisingly, if you use "localhost" for the IP address, it seems to allow it.  Thus, that might work.
Quote from: dkulp on December 10, 2020, 09:34:43 AMSurprisingly, if you use "localhost" for the IP address, it seems to allow it.  Thus, that might work.
ok, I see it now.  I grepped for 127.0.0.1 but didn't see the code that loops through the local IPs to make sure we aren't sending to ourselves.
sirwesley
setting it to "localhost" works!
Before I saw your replies I also was able to get it working by commenting out the following from the UDPOutput.cpp, but I much prefer not touching the codebase, so I'll go with the 'localhost' trick.
if (myIps.find(host) != myIps.end()) {
                // trying to send UDP data to myself, that's bad.  Disable
                LogWarn(VB_CHANNELOUT, "UDP Output set to send data to myself.  Disabling - %s\n",
                        host.c_str());
                //o->active = false;  // <-- This was turning it off.
Thanks @dkulp && @CaptainMurdoch !!
My box is now completely self contained and I'm controlling my Philips Illuminate lights without any modifications to its hardware from FPP.  Let there be Light...in a 'controlled' way of course!  ;D 8)
sirwesley
How would I go about requesting a parameter to 'disable e1.31 server' that I had to disable to get my server running?
Maybe the param would only be visual for developers, but something I could tap into with my future plug-in?
I am going to look at adding a setting to the master branch for testing.
The eventual goal is to merge bridge and player modes so that you can be playing a sequence and still receive E1.31 to merge with the playing sequence.  This could be useful for something like merging in data coming from a remote camera or another program that can generate E1.31.  In this case, you would be able to disable the network listeners totally since there would be no 'fake' listeners anymore.
sirwesley
What ever came of this.  I've updated to the latest version and attempting to run my own E1.31 server on the Pi.   Again hitting the "Error: bind EADDRINUSE 0.0.0.0:5568"
Seeing as this has been 4 years ago since I posted, thought maybe there might be a new setting in here somewhere or a new way to disable it, without 'recompiling' the code.
sirwesley
Took me some digging to figure out how to flip the newer version into develop mode, but then found it!
Disable Network Bridge Monitoring (E1.31/DDP/ArtNet)
