Total Members: 16966
Latest: lightsonpioneer
New This Month: 4
Total Topics: 17038
Most Online Today: 140
Guests: 124
Total: 124
Abnormal Conditions - May cause poor performance
Started by Tom0Pix, March 05, 2024, 09:19:49 AM
Tom0Pix
Hello again,
I have my next problem and don't know what to do next.
I have a Hanson HE 123 with 2 extensions. This is also licensed for 48 channels. Everything works so far with a test setup. 140 pixels on one connection works perfectly. In the BBB browser, the following status appears in red:
Abnormal Conditions: May poor performance
A log level is set to debug
After searching for something I found the logs
The following is in the ini log:
Tue 05 Mar 2024 04:52:00 PM CET
FPP - Setting up for the Falcon Player on the BeagleBone Black platform
FPP - Checking for required directories
ls: cannot access '/home/fpp/media/config/interface.w*': No such file or directory
ls: cannot access '/sys/class/net/wl*': No such file or directory
net.ipv4.ip_forward = 0
FPP - Clearing reboot flags
FPP - Sanity checking storage device setting
FPP - Setting max IGMP memberships
ln: failed to create symbolic link '/opt/fpp/www/proxy/.htaccess': File exists
FPP - Screen blanking deactivated
there are more logs available. I have no idea what this all means - apparently it can't find a file
Maybe one of you can help me so that my Mega tree project doesn't fail completely.
I can also post the other logs here, but I didn't want to flood everything.
Thanks in advance
Warm greetings from Germany
Tom
Quote from: Tom0Pix on March 05, 2024, 09:19:49 AMthe following status appears in red:
If this is the error you are trying to fix, then go to Status Control>FPP Settings>Logging and change all of your logging to Info. Debug logging level can take up a lot of resources and that is why you are getting the message. Those error messages might not be errors for your actual use case.
Compudon
I am getting an Abnormal Conditions Error Can Not Parse /home/fpp/media/config/co-universes.json.  This also seems to delete all my OUTPUT settings after a few minutes.
I've set Logging to INFO. I've downloaded and installed several versions of FPP - now I'm using FPP 8.5.1.  I've also installed different versions on two different Falcon Pi's.
I've used FPP controllers for the last 7 years without any of these problems.
If anyone knows how to help me with this I'd appreciate it!!
Thanks  Don
