I re-installed 4.1 on my 2B+ pi and I've not gotten the trigger to work properly ever since. Please take a look at the logs and the screen shots to see if I've made a mistake. BTW: the playlist Donation works fine when played separately .
Also look at the playlist called: 2020+Remote+falcon+Default+Playlist it seems that I can't delete it. It is also the name of the playlist that is playing on the master FPP. Normal/forget about it/bug?
Also the playlist Donation is Media only plus a script call to return the player to "Remote", which appears to work.
The master and remote are sync'd up nicely.
Do you have the Remote Falcon Plugin installed or previously configured?
That's what I removed from the remote. I also did a clean install of 4.1 and I added all on the video, audio, and FSEQ (which I deleted later per comments made by the captain). I'm only running the Media files to a HDMI TV.
I'm currently looking through the manual looking for clues. BTW: before I made the changes to the remote everything worked! Very frustrating!!
fixed
