I have several Raspberry Pis with Falcon Picap running FPP 4.5 at different homes. I am not seeing a way to tell that FPP to only control the picap on it (possibly including the LOR coming off the Picap)
Is there a way to do this? I noticed on FPP Connect in xlights that you can "check" the picap, but the dropdown for UDP control only has none, all or proxy. I understand how proxy works, but that doesn't help with a picap.
If you set UDP to "none" then that FPP will only send data to the directly attached PiCap. UDP is what tells FPP to send data out of its network interface to other controllers
I tried that, but it doesn't look right. seems to only look right in Bridged mode. I will try again tonight. Thanks.
Quote from: sirdevan on December 02, 2020, 11:28:54 AMI tried that, but it doesn't look right. seems to only look right in Bridged mode.
Can you provide more detail please? I have no idea what looks right or doesn't look right to you.
