Other Controllers and Hardware => General Hardware => Topic started by: ebrown19721972 on March 03, 2016, 10:42:35 AM
Title: Pigtail extensions
Post by: ebrown19721972 on March 03, 2016, 10:42:35 AM
Hello. Most of the extensions I see that are being sold shows them to be 5 volt. All of the pixels I have purchased are 12 volt. I am looking for 3 core 10-15 foot waterproof extensions to work with my 12 volt pixels. Can someone point me in the right direction as I have not bought these before. Thanks
Title: Re: Pigtail extensions
Post by: rstehle on March 03, 2016, 10:52:47 AM
Any of the 3 Core Waterproof extensions on the market can be used for either 5v or 12v.  Strong suggestion is to buy all of them from one vendor, as they may not interchange from vendor to vendor.
Post by: tmeyermn on March 03, 2016, 10:54:24 AM
HC has them:
http://www.holidaycoro.com/3-Conductor-Waterproof-Extension-Pigtail-10ft-p/727.htm
http://www.holidaycoro.com/3-Conductor-Waterproof-Extension-Pigtail-20ft-p/734.htm
Post by: Phrog30 on March 03, 2016, 11:43:17 AM
I bought mine from HolidayCoro, but half of them allowed water into the connector.
I have since went to these:
http://www.amazon.com/gp/aw/d/B00VZOHVSE/ref=mp_s_a_1_8?qid=1457030421&sr=8-8&pi=AC_SX236_SY340_FMwebp_QL65&keywords=crazyeve&dpPl=1&dpID=41jRVTCYN5L&ref=plSrch (http://www.amazon.com/gp/aw/d/B00VZOHVSE/ref=mp_s_a_1_8?qid=1457030421&sr=8-8&pi=AC_SX236_SY340_FMwebp_QL65&keywords=crazyeve&dpPl=1&dpID=41jRVTCYN5L&ref=plSrch)
If you buy your own cable you can make your own. You will most likely save money.
Just one idea.
James
Post by: ebrown19721972 on March 03, 2016, 12:02:15 PM
I did assume that all 3 core connectors would work but wanted to verify before purchasing any. Has anyone purchased any from diyled express before? Price seems reasonable.
Post by: rlemery on March 03, 2016, 12:12:44 PM
Diyledexpress is a good vendor but there pigtails will not work with other vendors and most the time they are out of stock when you need them the most.
Post by: ebrown19721972 on March 03, 2016, 12:23:43 PM
Maybe I will order a handful from Ray wu and see how those are
Post by: bravado67 on March 03, 2016, 01:40:34 PM
I did. I purchased 32 Pigtails and unfortunately they are too small for the lights I am ordering from Ray Wu. I also ordered 4 sets of RGB from CreativeLighting to begin playing as soon as I get my F16V2-R systems. They don't fit these lights either. It's my fault for not knowing what I was doing. I believe 13.5mm is more of a standard for many of the rgb bullet nodes for pigtail fittings.
Ron
Post by: rlemery on March 03, 2016, 01:49:04 PM
I use the 13.5 mm black one from Ray for everything. You can even buy his extentions and cut in two to get a short one for the controller and the long pcs for the pixels.
Post by: ebrown19721972 on March 03, 2016, 02:38:46 PM
Ron
Looks like I will need to do some measuring before I order. Thanks for the heads up on that
Post by: ebrown19721972 on March 03, 2016, 02:40:19 PM
Just one idea.
James
When making your own what kind of wire do most use?
Post by: bravado67 on March 03, 2016, 02:41:49 PM
Ron
No worries. This is what I should have looked at before purchasing:
http://www.diyledexpress.com/index.php?main_page=index&cPath=37_39&zenid=c62af770dabe15ebb2c0ee8151e291a3
Ron
Post by: Phrog30 on March 03, 2016, 02:42:44 PM
I've been buying 16/3. I have long runs. If you have short runs you could get by with 18/3.
James
Post by: ebrown19721972 on March 03, 2016, 02:49:51 PM
James
Any particular place you get your wire from or do you just buy it from a hardware store?
Post by: Phrog30 on March 03, 2016, 02:51:01 PM
Lately I've found the best prices on eBay.
Post by: ebrown19721972 on March 06, 2016, 05:57:34 AM
Is it a bad idea to use cat5 or cat6 cable to make my own extensions? I know this cable is very thin wire but with the twisted pairs I can double up the wires. Any ideas on this? Thanks
Post by: ebrown19721972 on March 06, 2016, 06:33:33 AM
Or would this be a little better
http://www.ebay.com/itm/131638101000?_trksid=p2055119.m1438.l2649&var=431008754897&ssPageName=STRK%3AMEBIDX%3AIT
Post by: Skunberg on March 06, 2016, 06:40:19 AM
Solid cat5 doesn't tolerate the bending of putting it up and down every year. Some are very careful and make it work, others have a nightmare. If you do, make sure you don't double up the data. It will cause signal problems. Pigtails 13.5mm from Ray and DIYLedExpress.com I intermixed without issue. But I agree to buy a batch together for every project.
Post by: JonB256 on March 06, 2016, 06:49:52 AM
That audio cable looks pretty good. Stranded, 4-wire. Seems like a good price for a 250ft spool, too. 16gauge or 14gauge.
Post by: danj on March 06, 2016, 09:22:46 AM
I have purchased waterproof connectors from DIYLEDexpress and from HolidayCoro.   We had torrential rains last Christmas and none of my connectors had any problems.   ....my two cents...
Post by: ebrown19721972 on March 06, 2016, 09:50:37 AM
I have a few coming from diyledexpress. I will also be making some custom extensions with pigtails i purchased from pixel sequencing
Post by: Phrog30 on March 06, 2016, 11:10:41 AM
I wish I was that lucky. After Christmas I took a few cables that hadn't been touched. I connected each end and submerged in 2" of water, they all failed. So the point of failure is the connector, not any splice or joint that I created.
It's possible mine were part of a bad batch. Mine were all from HolidayCoro.
James
