Falcon Christmas => Falcon PiCap => Topic started by: sth2258 on December 08, 2017, 04:16:46 PM
Title: DMX Spinning Head + PiCap
Post by: sth2258 on December 08, 2017, 04:16:46 PM
Hi Gents,
Need some help setting up a new DMX spinning light on a PiCap. I followed the below guide to create an ethernet -> XLR cable, and purchased a spinning light from Amazon (link also below).
Inside FPP (the one with the PiCap), I enabled a DMX output but am not able to get any lights to work; either through FPP or Xlights.
Any thoughts on where I am failing?
https://stevenbreuls.com/2014/03/diy-usb-dmx-controller-for-under-10_2_ethernet_cable/ (https://stevenbreuls.com/2014/03/diy-usb-dmx-controller-for-under-10_2_ethernet_cable/)
https://www.amazon.com/gp/product/B073PBHGYJ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 (https://www.amazon.com/gp/product/B073PBHGYJ/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1)
Title: Re: DMX Spinning Head + PiCap
Post by: CaptainMurdoch on December 09, 2017, 12:12:54 AM
His wiring looks correct, but he did number his pins wrong.  DMX data is on pins 1-2 which are what he has labeled as 7-8.
https://eventhorizon-srv.com/ecommerce/os/catalog/images/options/full/RJ-45_PinoutB_full.jpg
Did you create an OpenDMX Channel Output on the FPP Channel Outputs page?
If you are on the correct pins, you might want to try reversing your +/- pins to see if that fixes the issue.
Post by: sth2258 on December 09, 2017, 07:50:59 AM
Thanks for the reply Cap.
I used T-568B on the RJ45 end (tab down):
W/O
O
W/G
B
W/B
G
W/Br
Br
On the XLR end:
1 - W/O
2 - O
3 - W/Br
On FPP - I setup DMX Open; Start Ch 970 (I have 969 channels of pixels connected to the PiCap), 11 channels (as setup on the device) and tried both ports (ttyAMA0 and ttyS0).
Post by: CaptainMurdoch on December 09, 2017, 12:04:43 PM
Check out this diagram, does  yours match?
http://www.halloweenforum.com/attachments/tutorials-and-step-by-step/112609-diy-dmx-contrlled-rgb-led-light-step-11.jpg (http://www.halloweenforum.com/attachments/tutorials-and-step-by-step/112609-diy-dmx-contrlled-rgb-led-light-step-11.jpg)
For the PiCap, you want ttyAMA0, that is the onboard serial port
Post by: Zimerhonzl on March 14, 2019, 08:14:53 AM
Slightly out dated topic, but trying to streamline threads for future reference.
I followed the final diagram listed on the thread with no luck (this appears to be the Color Kinetics Standard), I have also tried the ESTA standard which switches the +/- wiring.  In both instances I am using port ttyAMA0 and my devices show that no DMX signal is being sent.  If I bypass the PiCap and use a Enttec DMX USB PRO Mk2 (port USB0), everything works fine.  The PiCap connectors are set to DMX, not LOR or REN.  Is there something else I am missing?
Post by: CaptainMurdoch on March 14, 2019, 08:54:49 AM
If you have not checked the "Always transmit channel data" setting on the FPP settings page, then FPP will only send channel data when playing a sequence or have channel test mode enabled.  Were you playing a sequence when checking the different wiring connections?
Post by: Zimerhonzl on March 14, 2019, 11:59:22 AM
Yes, I saw that in another thread and had it checked (sorry forgot to mention).  I am also running a sequence with constant fades to make sure the data always changes.  No luck using the built-in FPP display testing either.
Both the sequence and tests work with the Enttec device, even without the 'always transmit' checked, that's why I was wondering if there was something specific on the PiCap.
Post by: CaptainMurdoch on March 14, 2019, 12:19:00 PM
What version of FPP are you using?  I recently tested both Pixelnet and DMX output on the PiCap with the FPP v2.x image and confirmed they are working correctly.
I believe the Enttec device always transmits even if it is not receiving data on the USB side because the Enttec is a smart device with an IC to convert the incoming USB data to the DMX protocol on the ouput.  The PiCap connects the Pi's serial port to the RJ45 via a RS485 IC, so FPP has the responsibility of always transmitting DMX data.
Post by: Zimerhonzl on March 14, 2019, 12:31:00 PM
I am using FPP 2.6.
Post by: CaptainMurdoch on March 14, 2019, 12:51:14 PM
And you are using the "DMX-Open" Channel Output with the PiCap?
Post by: Zimerhonzl on March 14, 2019, 01:48:17 PM
That is correct!
Post by: Zimerhonzl on March 15, 2019, 01:46:38 PM
So, in line with my other thread, I re-flashed with a fresh copy of FPP 2.5.3.  My PiCap is now sending DMX and I am getting the original poster's issue of constant white lights.  I have flipped pins 1&2 and get the constant white still.  The image posted from the Halloween forum does not specify the ground, so I have used G/W per typical RJ45/XLR3 standards.  Any thoughts?
Post by: CaptainMurdoch on March 15, 2019, 03:00:48 PM
What is "G/W"?  Green/White-green?
Post by: Zimerhonzl on March 15, 2019, 04:24:28 PM
Green with white stripe.  Pin 3 on T-568B
Post by: Zimerhonzl on March 15, 2019, 05:30:14 PM
I am wondering if it is an issue with the PiCap itself.  Even if I have all outputs disabled in FPP the light style runs.  After blocking some of the lights so I could look closer, it actually looks like the white is staying on and the RGB are quickly cycling.  This starts as soon as I connect to the PiCap DMX event if I have display testing off and/or all channel outputs disabled.  :(
Post by: CaptainMurdoch on March 15, 2019, 09:38:45 PM
The PiCap is outputting DMX on pins 1 and 2 when using the DMX jumper settings on the PiCap.
Post by: Zimerhonzl on March 16, 2019, 08:38:59 AM
OK, that's how I have it all wired.  But I would think it should not be sending any data when all outputs are de-activated and no sequence or test mode is running in FPP, correct?  I cannot figure out why the PiCap sends a chase across channels 1-3, and channel 4 at full inherently.  Should I address my fixture higher?  My sequence will only be using DMX and no other protocol.
Post by: algerdes on March 16, 2019, 08:48:51 AM
There are some DMX fixtures that require the third wire - "ground".  (I have some that do, and some that do not.  Go figure.)  If I remember correctly, that is pin 7 and/or 8 in the RJ45.  It is pin 1 in the XLR.  For those same fixtures, without that ground, strange behavior is seen.  Pehaps this is what you are seeing.
Post by: Zimerhonzl on March 16, 2019, 09:04:36 AM
That was it!  I had tried pin 3 and pin 6 on the RJ45 based on some other pin out diagrams, but it turned out to be 8.  Thanks!  DMX can be so finicky...
Post by: Kjam22 on March 26, 2019, 02:39:45 PM
Do you have any video of this light running?  I have been wanting to put a few of these on the house
