Other Controllers and Hardware => General Hardware => Topic started by: vcuncg on August 29, 2018, 11:09:01 AM
Title: New show router suggestion
Post by: vcuncg on August 29, 2018, 11:09:01 AM
My current (cheap) router is lagging and needs to be replaced.  Before just buying a new one, I was curious if anyone has had success with a specific model or if there are ones that should definitely be avoided.  I have 2 F16v3s, one Renard TR24 and am using FPP 1.10. Thanks!
Title: Re: New show router suggestion
Post by: gadgetsmith on August 29, 2018, 01:45:16 PM
My personal suggestion is Ubiquity XRouter. This can act as both home and show router in one.  If wireless is required, appropriate AP's can be added. Personally I have an AC-PRO and AC-Mesh on my home network, and two nanostation loco M2's doing wireless with a handful of ESP controllers on my show side.
Post by: jnealand on August 29, 2018, 04:01:21 PM
How do you know it is the router causing lagging?  I use a Dlink router for my show that is at least 10 yrs old and it works fine.
Post by: Sawdust on August 29, 2018, 05:45:28 PM
EdgeRouter X is a great router, but if you are not a network person, you will need help setting up.
Post by: JonB256 on August 29, 2018, 05:59:49 PM
I'm with Jim. You may be trying to send too much data (bridge mode) over wireless.
Post by: K-State Fan on August 30, 2018, 05:56:25 AM
I use an Asus router with wrt firmware installed.  It has been very stable for me.  I have an Ubiquity UAP-AC-PRO-US access point installed in the attic which gives me a good signal in all my yard.
Post by: vcuncg on August 30, 2018, 09:07:37 AM
Thanks for all your help. It turned out that it probably was the router. It finally gave up the ghost and died last night.  :-\ Will not turn on again. I am glad to know that a simple one will work just fine, so I will go pick up a new one and get back to the fun. Thanks again for always providing help for my silly questions
