Falcon Christmas => Falcon PiCap => Topic started by: Discoeye on January 11, 2019, 09:23:05 AM
Title: FIRST TIME ADVICE FOR FALCON PICAP SET UP HERE IN THE UK
Post by: Discoeye on January 11, 2019, 09:23:05 AM
Hi to all on the forum. I am a uk resident setting out on my first adventure to controlling pixel lights via a pi 3b+ and a falcon picap
for christmas of 2019.
I am a complete novice of all devices but consider myself very competent if given the right guidance , i have read the best approach is to work backwards from the amount of pixels i will be using to determining the power required.
I value any help possible please from the forum to help me in my quest.
regards discoeye
Title: Re: FIRST TIME ADVICE FOR FALCON PICAP SET UP HERE IN THE UK
Post by: Bwinter on January 11, 2019, 10:32:30 AM
So what specifically are you stuck on?  Installing FPP, wiring, configuring?
Post by: Discoeye on January 11, 2019, 11:52:23 AM
Hi,
thanks for looking at my post. I am awaiting my falcon picap and im confident with the software side of things with my pi 3b+ its just the wiring side of things.
My project is to make 4 chasing arches/arcs over a distance of 8 meters so 2 meters per arch/arc and i have no problems making these i thought strip pixels and tubing but im unsure on 5v or 12v lights and the whole wiring process.
Thank you and kind regards Discoeye
Post by: Bwinter on January 11, 2019, 11:56:19 AM
I think you'll be in pretty good shape.
Have you selected what type of LEDs you're going with?  Bullets/nodes or strips?  Are the LEDs inside some tube (i.e., weatherproof), or are the LEDs going to be exposed?
Basically, you want WS2811/WS2812 (WS281x) type of LEDs.  They have a wire/connector for VOLTAGE (5v or 12v, your choice), GROUND and DATA-IN (connected to DATA-OUT of your PiCap).
Post by: mac50 on January 11, 2019, 12:12:07 PM
Here is a video on power calculation   https://www.youtube.com/watch?v=XxOdUJweQbA
Post by: Discoeye on January 11, 2019, 12:21:06 PM
Hi,
thanks for the link.
Kind Regards Discoeye
Post by: Discoeye on January 11, 2019, 12:33:40 PM
Thank you ever so much.  So Picap on top of rpi 3b+ power supply to cap which would power rpi ????? lights from cap
would that be correct.
I have the link with regards to calculating how much power which will determine what psu to get, any additional wiring i need to know of or would be wise to have .
Forgive me for all the questions but i don't want to go out in a puff of smoke.
Post by: Bwinter on January 11, 2019, 12:39:33 PM
Many people supply power through the PiCap--and this powers both the Pi as well as the LEDs that are attached (makes the overall wiring much simpler).
However, there has been some reports that the Pi 3B+ draws more power than the PiCap's on-board buck-converter can provide.  In this instance, you might need to power your Pi3B+ separately from the LEDs.
Post by: Discoeye on January 11, 2019, 12:50:17 PM
Ok thanks for the heads up. Any recommendations for a good power supply i think i will be going with 12v pixel strip lights.
Thanks and kind regards Discoeye
