Other Controllers and Hardware => Renard Controllers => Topic started by: kdoyon on October 24, 2017, 10:34:42 AM
Title: FPP on Pi not sending anything to Renard SS8
Post by: kdoyon on October 24, 2017, 10:34:42 AM
Hi everyone,
I have recently jumped into this hobby, and I am at a sticking point.
I am able to use vixen on my computer to send data to a Renard SS8, and the lights hooked up to it will light up. I am connecting the computer to the Renard with a USB to RS485 adapter. I did have to go in to display setup and tell Vixen that the Renard controller was on COM 4 instead of COM 3 like it first thought. Then everything works fine.
However, when I hooked up the Renard to my Raspberry Pi B with FPP running, I cannot get the lights to light. I have tried both the channel test and sequence test (uploaded a fseq file exported from vixen. The same file that works when the Renard is directly connected to the computer running Vixen.
I have attached a picture of how I have the Renard controller set up in Channel Outputs. The only thing I noticed that I don't understand is that the only choice for port was ttyAMA0. Not sure what that means or if it is what I need.
(https://photos.google.com/photo/AF1QipPR0IzfYiuHq_G3LB5DY-aIkgjtVB4vjLQrw6-9)
Any help would be appreciated.
Ken
Title: Re: FPP on Pi not sending anything to Renard SS8
Post by: JonB256 on October 24, 2017, 10:48:36 AM
Was the Renard USB dongle plugged in when the Pi booted? Many USB devices need to be sensed at boot to be properly listed by their tty address.
Post by: kdoyon on October 24, 2017, 11:43:15 AM
Darn. I was hoping that might be it. I rebooted and tried it again. Nothing. Then I did a full shutdown of the Pi and started it back up. Nothing.
Any other ideas?
Post by: JonB256 on October 24, 2017, 11:48:28 AM
other than varying the baud rate or Com parameters, no.
There are others here who do Renard (I don't) who may know more.
Post by: kdoyon on October 24, 2017, 11:56:25 AM
Thanks for trying!
Post by: dakingus on November 04, 2017, 05:28:05 PM
I use FPP to drive 32 channels of Renard.  On my Channel Outputs page the I have the port set to ttyUSB0.  You might try that.
Post by: CaptainMurdoch on November 10, 2017, 11:35:51 PM
This is probably it.  ttyAMA0 is the onboard serial port on the Pi, so you only want ttyAMA0 if you are using something like a PiCap to convert that to RS-485.
For USB dongles, you want the ttyUSB0, ttyUSB1, etc. devices.
Post by: XmasLightGuy on November 25, 2017, 05:41:03 PM
I used ttyUSB0 for my renard going through a USB dongle.
But I also had to build a small crossover board to go between the dongle & Renard.
Then I was able to get lights :)
