Falcon Christmas => F16V2 Differential Expansion and Receivers => Topic started by: bucknut on February 05, 2018, 09:30:27 PM
Title: Power Receiver Board from pixels
Post by: bucknut on February 05, 2018, 09:30:27 PM
Is it possible to power the receiver board from the pixels rather than running a line directly from the PSU?  I'd like to power inject mid string only and use that to power the receiver board if possible....?
Title: Re: Power Receiver Board from pixels
Post by: Emuney18 on February 06, 2018, 05:26:11 AM
Are you asking if you could take the end of a string and plug the V- and V+ into the receiver?  That sounds like a bad idea for a whole bunch of reasons.  You can run a line direct to the receiver from a distant power supply.  I have done that before using 12awg wire.
Post by: bucknut on February 08, 2018, 07:58:55 AM
The reason I ask is that I saw a post on another forum but don't understand if the power would just flow through the pixel output in reverse or not. The other post is
"Haven't tried this myself, but it should work. The receiver board does need power. But you should be able to power it from the pixel string. Power isn't directional. It goes both ways down the wire. If the pixel string is powered from somewhere downstring, just connect all 3 wires to the receiver and that would backfeed power into the receiver board. It should power up and work fine.
From the sounds of that it wouldn't be necessary to power the board itself but instead power the pixel string and allow it to power the board. I was just curious if that was actually possible. I don't have a receiver board in hand yet so I can't test it myself.
Post by: Emuney18 on February 09, 2018, 06:24:18 AM
Based on the fact you can power the main F16 board by putting power into one of the outputs for initial setup, I would think it's possible.  I wouldn't do it unless that was the only string I was going to plug into the receiver board because more strings would be more power draw on the pixel wires which are not huge to begin with.  At that point I would still rather use a 50-75watt power supply with the board.
Post by: DMJPixel on November 03, 2018, 09:42:04 AM
Did you ever try this out?  Have some boards on the way and was searching the forum for the same question.
Post by: bucknut on November 19, 2018, 07:45:49 PM
Never tried it out.  I had an extra outdoor rated power supply, so I hung the power supply under the eve and put the receiver in a TA-200 box instead.  I'll work on testing the other way after this years show.  Never enough time...
