Total Members: 15659
Latest: PaulDzRGB
New This Month: 9
New This Week: 3
Total Topics: 15791
Most Online Today: 27
Guests: 23
Total: 23
F16 v2 rebooting/shutdown
Started by Jojoed, June 01, 2020, 10:10:57 AM
Jojoed
So I was testing out some lights I recently got and I plugged in all 16 ports with 100 strand 12v 2811s also hooked up my exp board and hooked 8 more to it
I have too  power supplies hooked up one on each bank
But when I power up and try running test mode my controller shuts down
Am I pulling to much power or is this a setup issue
I did not change any of the allocated pixels to the exp board seeing how there's only 100 pixels per port didn't see a need to
Sent from my SM-G981U1 using Tapatalk
If I followed what you said, you have 2,400 12V pixels on two (I'm assuming 350W) power supplies.  If you have those on full white, you are almost certainly attempting to draw far more power than those two supplies can deliver.  My rule of thumb for 100% white pixels is 400 pixels at 12V and 1000 pixels at 5 volts.  Both of those allow a little headroom (more so on the 12V by a little).  If you are running lower percentage, you can get more pixels per power supply.
Now before someone calls me on my rule of thumb numbers, to be picky at 5V the max count is 1,166 pixels and at 12V the max count is 483.  Both of those figures assume 60mA per pixel - and there are differences.  However it is bad engineering practice to plan on running any power supply at 100%.
Put a volt meter on the power supply output when you do your test and you will see the voltage crask.
Jojoed
Ahh gotcha that's what I was thinking but just wanted to make sure as u all are far more experienced than I
Btw these were the lights you sold me
So I'm assuming I need to add an additional power supply or too to run my mega tree
I haven't had to power inject much as I'd never run 100 percent
 is there a simple way to add more then 2 power supplies? With out risking over powering I know to add a fuse but just looking for a little guidance maybe a pic of ur setup u ran them on perhaps
Last two years, I ran those lights from two SanDevices E682 controllers.  Each half of a controller had a separate power supply and even with that, I had to run them at 50%.  If you do it with three power supplies, I would just use a third power supply on the expansion board.  If you want to split it out to four power supplies, re-arrange the strings a little so you use six output of each half of a board - i.e. outputs 1 - 6 and 9-14 on both the controller and expansion board for example.
Jojoed
Ok thanks for the information I appreciate it
Warning/Error: Network incomplete frames hit 250. by JonD
February 06, 2023, 04:10:22 PM
F16V3 with 2 expansion boards at 40 fps MAX PIXELS per output? by tbone321
February 06, 2023, 10:51:55 AM
F48V4-NS at 40 fps using all 48 pixel output ports? by Poporacer
February 06, 2023, 10:27:09 AM
Unable to update RPi 5.5 to latest version by JonB256
February 05, 2023, 07:23:16 PM
help getting started, next step? by rayster
February 05, 2023, 04:24:09 PM
F48v4NS - Pi or No Pi? by joeyblasko
February 05, 2023, 09:15:33 AM
Huidu Controllers LED matrix by CaptainMurdoch
February 04, 2023, 10:18:47 AM
FPP6.2 universes by darylc
February 03, 2023, 08:48:57 PM
F16v4 Ports vs Universe Configuration Question by k6ccc
February 03, 2023, 09:32:48 AM
Need Expert Advise on F16v4 Ports vs Universe Configuration by Kairus
February 03, 2023, 09:32:33 AM
